![]() | Home > Maintenance & Modifications > Couple of little mods from a new owner |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
very nice and a lot planned too. I do like them in white (saw a pink one yesterday )
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
Thanks |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Your car looks fab mate |
Thank you |
Yep thats the audi i saw, looks gr8 |
That's correct just chopped off and welded in place 2 straight pipes unfortunately I don't have any before and after pics, I will be going for a custom cat back with just the 2 rear silencers, I will be doing away with the centre silencer and the cross over box, I'm pretty sure that will be the sound I am going for. |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
LED side lights look so much better |
will u be fitting the cross over box in replace with the straight pipes fitted?
Just noticed my fog lamps are a bit yellow so that's something else I will be upgrading. I will be using a custom exhaust place to make me one up, not too sure about the crossover box and how much it is needed but if I can do away with it I will do as that with it being ported will hold back a lot of the noise |
JayJay Member Since: 27 Feb 2014 Location: wolverhampton Posts: 50 ![]() ![]() |
Very nice mate... |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
nice clean engine bay |
Hi Gogsy, thanks it's actually quite easy to do, I first applied some Autoglymm engine/machine wash and agitated with a soft brush for a few minutes I then started the engine and pressure washed off staying clear of the battery cover as that is where the ecu is, I left the engine running for 10 minutes and turned off and left over night to dry thoroughly. The next day when it was dry I got out the Meguires dash & trim restorer and a yellow Polish pad and did the scuttle panel and all the black bits in the engine even the hoses etc etc I am happy with the finish and it has made the engine bay look so much better. Here are the things I used minus the brush which I got in the halfords 3 for 2 offer. |
Today's little mod |
Nice - funnily enough I've just done the exact same mod (look in my gallery) a few hours ago to my Sport. I much prefer the look of white indicator lenses than orange, they're more modern and clean looking |
