Home > Technical > Video camera
Hugh Haddow
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Video camera
I'm considering fitting a camera, probably a RoadHawk. I'd like to 'hard wire' it. But cannot find a wiring diagram.
Has anyone any experience in this area or advise where I can find a wiring diagram?
Thanks
Hugh
Post #395690 Sat Sep 21 2013 3:09pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
I've just fitted a BlackVue 500 today using Muddy's guide
Don't know how to paste a link but if you search for "Blackvue" it's obvious which thread is the hardwire install guide. Also a recent thread about wiring into the interior light
Post #395700 Sat Sep 21 2013 4:37pm
chrisebabes
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Fitted my Road Hawk last week its a great picture, I just ran my power lead round to the rear power outlet so I can still use the front one if needed. I have turned the voice thing off though not able to understand a word it says !!! Cool TDV8 2007 window tints, side steps.
Post #395736 Sun Sep 22 2013 7:48am
Hugh Haddow
Thanks all. Bit undecided between the Blackvue and the Road Hawk.
Like the idea of wiring to the rear socket though..
Post #395790 Sun Sep 22 2013 3:38pm
Paulcp
Just to add that before hard wiring the Blackvue I also ran the lead to the rear socket. The lead supplied was long enough to go underneath the headlining, down the front A frame trim, through the dash and along the back of the glove box, down the side of the passenger seat under the trim and still had about 50cm to spare which had to be tucked up underneath the console.
It was then just an easy reach from the driver seat to plug and unplug it.
During the hard wiring I also came to suspect that the socket in the rear of the centre console switches off automatically about 2 minutes after the ignition has been turned off and the drivers door closed. If this is the case (perhaps someone can confirm), then no need to keep unplugging it as I was doing since the battery wouldn't drain.
I hard wired with the Powersaver Pro kit which gives the option of having the camera running in "parking mode" or turning it off via a switch.
Post #395799 Sun Sep 22 2013 5:54pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I can recommend the Blackvue, good quality videos and WIFI to the phone.
Had mine fitted by the company that supplied it. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #395805 Sun Sep 22 2013 6:37pm
Hugh Haddow
Decided on the BlackVue. Have ordered and will report when tried.
Many thanks all.
Hugh
Post #396046 Tue Sep 24 2013 6:24pm
Hugh Haddow
BackVue installed and tested today. Worked first time out the box. Seemed so simple I decided to follow Paulcp and run it in myself to the rear seat socket. Works a treat although it took about ten minutes for the GPS to lock on.
Advice needed.
Since the A frame has an airbag in it which side should the wire be run. Door or windscreen?
Hugh
Post #396355 Fri Sep 27 2013 1:09pm
muddywheels
Milk Float Man
I ran mine down the windscreen edge so as not to interfere with airbags Thumbs Up
The rear socket is ok but will not give you park protection and takes a while to start up from ignition - if you're like me you want to turn the key and go - the camera will still be starting up when you have your first incident Laughing
If you decide to hardwire http://www.rrsport.co.uk/forum/topic28640.html?highlight=blackvue Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #396357 Fri Sep 27 2013 1:16pm
Hugh Haddow
Thanks Muddywheels. Good advice I think I will go for the power thingies for the parking function but that's beyond my capability. So I'll try it for a wee while then commission an expert I think.
The power up delay is not so important for me. At my age I don't do anything quick. By the time I remember where I'm going the thing should be on.
Thanks again
Hugh
Post #396379 Fri Sep 27 2013 2:53pm
paulL
Spain 2013 Range Rover Sport SDV6 Autobiography Fuji White
Hi guys
On a Blackvue 500, Is the standard wire long enough to run to the rear 12v supply?
Cheers 2013 RRS SDV6 Autobiography Fuji White
2007 RRS TDV8 HSE - gone -
2005 RRS TDV6 HSE - gone -
Post #396505 Sat Sep 28 2013 1:19pm
chrisebabes
Just to add that my road hawk starts as soon as I turn the engine on and its plugged into rear socket Thumbs Up TDV8 2007 window tints, side steps.
Post #396509 Sat Sep 28 2013 2:33pm
Hugh Haddow
The standard wire easily reached along the top of the screen, down the 'A' pillar, behind the glove box, tucked up under the centre console and up to the back seat socket. I had about 20-30 cm to spare.
Hope this helps paulL.
I've now 'played' with my Blackvue over the weekend and am so far impressed. The software is particularly good. Easy to use (it has to be for me) and very informative. Particularly the map of the trip.
It seams to work a treat from the back socket. Starts as soon as you enter the car and records after aproximately a minute then switches off a couple of seconds after it is locked. I may get the power pro later to ger the park function.
Hugh
Post #396614 Mon Sep 30 2013 10:39am
paulL
Many thanks Hugh. Mine is arriving this week.
Post #396624 Mon Sep 30 2013 12:07pm
Paulcp
The rear socket on mine is activated as soon as you open the doors. I believe that it also auto powers off after about a minute when leaving the vehicle so it may be ok to leave it plugged in.
I agree that the park safe mode is the way to go and following your good guide i managed to fit the Powersafe Pro in about an hour, putting the unit itself in the top glove box with the plug in connection of the cigar lead tucked up behind the trim by the passenger seat which can be easily unplugged if required.
The only irritation at first is that, because the accessory circuit becomes live as soon as you open a door (hence my comment about the rear socket) the camera powers on after a few seconds which is ok if you are driving off but a little irritating when you are cleaning the car etc. this is however something which you get used to.
Post #396670 Mon Sep 30 2013 5:25pm
