![]() | Home > Off Topic > Forgot to close the suroof and it rained :( |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
I had an MG fill with water due to problem with roof/cover - the dealer took carpet out and put it and car in the oven they used for curing paint overnight and was good as new |
With the way the electrics are in these things and you do that |
B.Safe Member Since: 28 Jun 2012 Location: London Posts: 113 ![]() ![]() ![]() |
I go to buy one today ![]() |
Morpheus-RRS Member Since: 29 Oct 2012 Location: Lanarkshire Posts: 83 ![]() ![]() ![]() |
A good dehumidifier left inside the car with the windows closed and the drain running outside will have it back to new |
chilly Member Since: 07 Dec 2010 Location: north east Posts: 192 ![]() ![]() ![]() |
get it dried out with heaters dehumidifier all put a baking try fill with baking soda in ther over night and repeat as this draws in odors and traps it you can also get some stuff by auto glym that is desgined to remove smells from carpets,
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
as said I would look at soaking it up as much as possible, wet vac, dehumidifier, i would also look at taking the centre console apart
Do you think this will do the job? It costs £94.97 at Argos and I will buy it only for this problem.
looks ok, do you park on the flat as this review says it doesn't like slopes
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Looks good although you'll need to remember to regularly empty the 1.5l tray otherwise you'll have a bigger problem |
I have 2 of these on my boat and there great, you should get a hose supplied so it can drain continually but as i said on my other post make sure all the windows and doors are closed or it will just suck all the moisture out of the atmosphere. You could leave it in the boot as it will then be on a flat surface and could drain through a grommet under the tool tray. Try and get as much water out as possible by other means as others have suggested and strip down the centre console and dry out.
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 ![]() ![]() ![]() |
I had the same issue on a different vehicle & it caused havoc with my electrics esp the seats.
^^^^^Dont drive with the candle lit^^^^^ |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Think I would give it to a detailer and let him sort it out, may be no more expensive than buying this or that and doing it yourself MY16 AUTOBIOGRAPHY Indus silver with some toys
