Home > Off Topic > Forgot to close the suroof and it rained :(
B.Safe
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
This is the only time in my life I forgot to close the sunroof and it rained all night Big Cry
I cleaned the car but it smells inside even after 4 days, I think I will sell it because of this Sad
Any idea how to get rid of the bed smell? I allready left it 2 hours full heat to dry. Big Cry
Big Cry
Big Cry
Big Cry /|\
Post #366150 Mon Dec 10 2012 3:56pm
muddywheels
Milk Float Man
I had an MG fill with water due to problem with roof/cover - the dealer took carpet out and put it and car in the oven they used for curing paint overnight and was good as new Embarassed
If you have a garage could you use a fan heater and dehumidifier Question
What about insurance claim Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #366151 Mon Dec 10 2012 4:01pm
With the way the electrics are in these things and you do that Shocked Shocked
The only thing you can do it let it dry fully. Perhaps try and get the carpet up if you can as if it was prolonged, you may find there are puddles of water under there too. Until you get rid of it all, you won't be able to combat the damp smell.
Do you have or know anyone with and extractor(wet vac). Could be worth buying one (around £75) and making sure you get as much water out of the carpets as possible.
Good luck Neutral ON THE WAY: BMW F21 M140i
Post #366152 Mon Dec 10 2012 4:02pm
B.Safe
Good luck Neutral
I go to buy one today Big Cry /|\
Post #366153 Mon Dec 10 2012 4:10pm
Morpheus-RRS
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
A good dehumidifier left inside the car with the windows closed and the drain running outside will have it back to new Thumbs Up
Could also try for an insurance claim (broken sunroof) Whistle Dave.
MY12, SDV6, HSE Orkney Grey, Cream leather with contrast stitching, Side steps, Tow bar and electrics, privacy glass.
Post #366155 Mon Dec 10 2012 4:12pm
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
get it dried out with heaters dehumidifier all put a baking try fill with baking soda in ther over night and repeat as this draws in odors and traps it you can also get some stuff by auto glym that is desgined to remove smells from carpets,
but main thing is geting it dry, could eve try putting rice down on the carpet and leaving overnight to draw out any mositure only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #366158 Mon Dec 10 2012 4:35pm
as said I would look at soaking it up as much as possible, wet vac, dehumidifier, i would also look at taking the centre console apart
You could also try cress seeds, they impregnate the carpet and soak up all the water whilst growing in the carpet Whistle
Post #366159 Mon Dec 10 2012 4:41pm
B.Safe
Do you think this will do the job? It costs £94.97 at Argos and I will buy it only for this problem.
http://www.argos.co.uk/webapp/wcs/stores/s...nformation /|\
Post #366160 Mon Dec 10 2012 4:41pm
looks ok, do you park on the flat as this review says it doesn't like slopes
Quote:
"I bought two of these because I had a condensation problem. They do the job but are sensitive to being on slightly sloping surface. I had one in a caravan and it would not work until I repositioned it. Otherwise they are fine. Good value. Fairly quiet but noisier than expected."
Post #366161 Mon Dec 10 2012 4:45pm
B.Safe
Rolling with laughter
Post #366162 Mon Dec 10 2012 4:46pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Looks good although you'll need to remember to regularly empty the 1.5l tray otherwise you'll have a bigger problem Laughing
Don't forget a wet vac too...there will probably be a lot of water under your carpet.
Post #366163 Mon Dec 10 2012 4:49pm
Morpheus-RRS
I have 2 of these on my boat and there great, you should get a hose supplied so it can drain continually but as i said on my other post make sure all the windows and doors are closed or it will just suck all the moisture out of the atmosphere. You could leave it in the boot as it will then be on a flat surface and could drain through a grommet under the tool tray. Try and get as much water out as possible by other means as others have suggested and strip down the centre console and dry out.
Once dry go to www.furnitureclinic.co.uk and get there leather care kit (£24.95) and clean and treat the leather which also put back the new leather smell, I've used there stuff to treat the boat, cars and suite in the house and find it really good.
Good Luck Dave.
Post #366164 Mon Dec 10 2012 5:23pm
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
I had the same issue on a different vehicle & it caused havoc with my electrics esp the seats.
Once all dried out and you want it smelling nice again...
Buy a Yankee Leather Scent candle set it up in the passenger footwell and burn it for as long as possible.
Mmm mmm it will smell just like new again.
Post #366171 Mon Dec 10 2012 6:21pm
Morpheus-RRS
^^^^^Dont drive with the candle lit^^^^^ Rolling with laughter or you will end up with an insurance claim Whistle Dave.
Post #366173 Mon Dec 10 2012 6:28pm
rigsby
Think I would give it to a detailer and let him sort it out, may be no more expensive than buying this or that and doing it yourself MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #366174 Mon Dec 10 2012 6:28pm
