![]() | Home > General > Tyre Advice - Are these Conti's Shot / Illegal? |
NoDo$h Member Since: 27 Mar 2007 Location: Darrrrrzet Posts: 88 ![]() |
275/45. It's within 1% of the rolling circumference of the 255/55/19s fitted at the moment and only 20mm wider.
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Howdy learned colleauges! Been a while. Paul your tyres look like mine |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
And your point is what exactly ![]() |
That the legal minimum is just that, and that changing your tyres a little earlier may just be the sensible thing to do?
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 102 ![]() ![]() |
I always look to replace mine a little early but how early depends on the season. If we're heading into winter I tend to replace earlier than I might otherwise. 2021 L494 D300MHEV Autobiography
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 273 ![]() ![]() |
Adding to the above question, for mainly motorway work and nothing more challenging than a wet grass verge, what would posters recommend. Im looking for price/longevity, ie value, above all else. RRS HSE Dynamic SDV6 2014 Nemo mortalium omnibus horus sapit |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 583 ![]() ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Same here. 1.6mm of tread in wet conditions is little better than a slick tyre on modern tarmac. I use ATs so I tend to change them at around 4mm (they start with more tread so the overall tread use is pretty much the same as with a road tyre changed early). My current Ats will probably be changed around October/November so that I get the full benefit in the worst conditions both on tarmac and off during the shooting season and if it snows. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
