Home > In Car Electronics > Upgrading 2012 screen to Dualview unit possible? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
The Hardrive is a Integral part of the Screen Unit. Whether it can be upgraded or not wouldn't know but would be inclined to think not.
Mon Mar 28 2016 10:47pm |
bitcrunch Member Since: 28 Mar 2016 Location: UK Posts: 16 |
Thanks for your response Col. Id like to give it a try, im a computer engineer by trade and delve alot into circuitry so I might investigate further and see what i can do.
Mon Mar 28 2016 10:59pm |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 330 |
The 2012 Range Rover Sport was not available with Dual View. The only Dual View in the previous generation was on the L322 from 10MY.
Tue Mar 29 2016 2:41pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
mine has dual view - registered 31 March 2012 16MY Estoril Blue SVR.............
Tue Mar 29 2016 2:57pm |
Really? Then I stand corrected. Apologies. |
Tue Mar 29 2016 2:58pm |
wireworld Member Since: 23 May 2014 Location: Shropshire Posts: 45 |
I had a 2013 RRS Black edition with dual view |
Tue Mar 29 2016 4:09pm |
Thanks for the input guys, i think ive found a dual view screen so once that arrives ill have a go at installing it and also trying to swap out the hard drive for an ssd to hopefully speed things up on the infotainment.
Tue Mar 29 2016 4:23pm |
Don't forget - you also need to change the fascia - buttons under the screen
Tue Mar 29 2016 4:27pm |
I have a 2012 RRS and the dual view screen should be exactly the same using the same fascia? Are you refering to the 2005-2008 dash peachy?
Tue Mar 29 2016 5:00pm |
In a Vehicle without Dual Screen it has a button on the dash which has Setup on it, in a Dual Screen vehicle this button has a Icon on it of in effect Two Screens on it.
Tue Mar 29 2016 5:08pm |
Check that the crashed one had Dual View as this was a Option not Standard Fit, although I believe it may have been in the Black Edition as Standard Fit. I'm afraid Peachy is right as there are different Part Numbers for the switch panel be it Dual View or Not. Cheers Col Last edited by Col on Tue Mar 29 2016 5:40pm. Edited 1 time in total |
Tue Mar 29 2016 5:24pm |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 119 |
Really interested to know if a straight swap will work. I presume the Config will need to be updated to enable the dual screen. Wonder if that config change also alters the function of the setup button?
Tue Mar 29 2016 5:34pm |
Soon as i recieve the screen ill take some pictures as i progress. Im hoping the screen That was sold to me was a dual screen as thats what i was told.
Tue Mar 29 2016 6:32pm |
I have the dual view on MY2012 RRS SDV6 HSE Lux and there is indeed a different button/switch for dual screen (not to be confused with the motorway junction readout and map which looks like a dual screen), I believe you will find there is a different control board for this setup, not just a switch change over I'm afraid. Details of both systems were in my owners handbook, which came with the car. John
Tue Mar 29 2016 6:44pm |
