Home > Technical > Annoying Rattle from Passenger Side
pTed
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
I've had a noise coming from the passenger side for some time now. It sounds like it's coming from under the front passenger seat.
It's a tinny/metallic/whirring/tapping - a bit like the sat nav disc firing up.
It occurs on smooth roads and gets worse the faster I go.
I've removed the Sat Nav disc and it still occurs.
It's been in under warranty and the dealer replaced a speaker claiming that was it, but the noise returned.
Before I stick in the dealer's for another fruitless few days, has anyone experienced similar or have any suggestions?
Post #161189 Mon Mar 24 2008 11:25am
Cyprus 2006 Range Rover Sport TDV6 HSE Java Black
Sounds like the sat nav unit as I seem to remember that is where you would have removed the disc from.
With the disc removed, does it still make the noise? Does the unit read the disc ok when it is in place?
Could just be a noisy unit that works ok, but not as quietly as other peoples Question 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
COME TO TROTTERLAND
http://trotterland.myminicity.com
HELP BUILD ROADS IN TROTTERLAND
http://trotterland.myminicity.com/tra
HELP JOBS IN TROTTERLAND
http://trotterland.myminicity.com/ind
Post #161195 Mon Mar 24 2008 11:44am
pTed
Yep, I'm pretty convinced it's the sat nav unit, but it makes the same noise with no disc in place.
I had a quick look at disconnecting the unit to prove it once and for all but haven't tried that yet as the cables were a bit fiddly to remove.
Post #161197 Mon Mar 24 2008 11:53am
Tim in Scotland
Do you have sill plates? I found that I hadn't stuck the drivers side one down hard enough and it was rattling on the underside of the door at speed on less than velvet smooth roads. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
TDv8 HSE - Stornoway Grey with ebony and straight grain walnut wood-a-like interior with towpack, Tasmods. The best car I have ever owned
Now departed - Giverny Green TDv6SE with Aspen and Parchment interior - nearly the best car I have ever owned
Staying - Epsom Green Defender 90 for playing off road
Post #161199 Mon Mar 24 2008 11:58am
pTed
Nope, don't have sill plates.
Post #161203 Mon Mar 24 2008 12:49pm
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Check your external door trim - if this is loose it vibrates the faster you go and makes a sound like the one you've got. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #161209 Mon Mar 24 2008 1:23pm
Jonathan
England 2008 Range Rover Sport TDV8 HST Java Black
just got back from ols so have missed thishowever I had exactly the same problem - take a look at your door trims at the bottom of your nearside door - they make this noise whenthey'e not pressed on correctly.
Hope this helps. RRS - Best Car I've Ever Had
R32 for the wife
Prev
645ci - Silver
Jag XKR - BR Green
BMW 530i MSport Black
BMW 328i - Black
Post #163528 Fri Apr 04 2008 9:58pm
monkey9952
Had this problem meself , untill i realised it was the wife Laughing
Now she gets the bus problem sorted Thumbs Up
Post #163531 Fri Apr 04 2008 10:08pm
Your wife was making a rattling noise? Shocked
Post #163833 Mon Apr 07 2008 11:34am
Location: Growing old is mandatory; growing up is optional.
Rolling with laughter Rolling with laughter Rolling with laughter RRS TDV6 Gone but still around
BMW 320D M Sport
And A Van For The Dog
Oh and i love the girlzzzzzzzzzz!!!
Post #163881 Mon Apr 07 2008 12:59pm
monkey9952
I assumed most women rattle on ? Shocked
Post #163895 Mon Apr 07 2008 2:57pm
You can stop the rattling by buying a replacement handbag I think.
Post #163896 Mon Apr 07 2008 3:05pm
Replacement? Don't you mean additional hand bag? RRS TDV6 Gone but still around
BMW 320D M Sport
Post #163905 Mon Apr 07 2008 3:38pm
I suppose - replacing the one she currently has, which will get chucked in the back of the cupboard only to find that in two weeks time, she has to go back to it because the new one doesn't have enough pockets, straps and buckles.
Post #163909 Mon Apr 07 2008 3:45pm
It's not really like that is it? Oh the joys of all i have to look forward to Evil or Very Mad RRS TDV6 Gone but still around
BMW 320D M Sport
Post #163916 Mon Apr 07 2008 3:54pm
