| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Annoying Rattle from Passenger Side |
| Supertrotter Joined: 10 Mar 2006 Location: In my office looking out at the sunshine :-( Posts: 6276
Sounds like the sat nav unit as I seem to remember that is where you would have removed the disc from.
| pTed Joined: 04 Feb 2007 Location: South Posts: 9
Yep, I'm pretty convinced it's the sat nav unit, but it makes the same noise with no disc in place.
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 7170
Do you have sill plates? I found that I hadn't stuck the drivers side one down hard enough and it was rattling on the underside of the door at speed on less than velvet smooth roads. |
Nope, don't have sill plates. |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14144
Check your external door trim - if this is loose it vibrates the faster you go and makes a sound like the one you've got. |
| Jonathan Joined: 11 Jan 2008 Location: York Posts: 98
just got back from ols so have missed thishowever I had exactly the same problem - take a look at your door trims at the bottom of your nearside door - they make this noise whenthey'e not pressed on correctly.
| monkey9952 Joined: 09 May 2007 Location: In A mess Posts: 124
Had this problem meself , untill i realised it was the wife |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 18511
Your wife was making a rattling noise? |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 18722
I assumed most women rattle on ? |
You can stop the rattling by buying a replacement handbag I think. |
Replacement? Don't you mean additional hand bag? |
I suppose - replacing the one she currently has, which will get chucked in the back of the cupboard only to find that in two weeks time, she has to go back to it because the new one doesn't have enough pockets, straps and buckles. |
It's not really like that is it? Oh the joys of all i have to look forward to |
Staying - Epsom Green Defender 90 for playing off road
