Home > General > TDV8 3.6 loss of power |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
Common problem is that the intercooler pipes deteriorate with age, easy and cheap fix so check those.
Sat Apr 17 2021 12:10pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
Does it smoke under load? Black smoke would suggest an intercooler pipe has split. White smoke suggests a turbo failing. If it's the latter, don't drive it until it's looked at because it's not unknown for a turbo failure to stuff enough oil in to the intake system to hydro-lock the engine. 2012 SDV6 - it's missing a couple of cylinders
Sat Apr 17 2021 1:15pm |
Callyp43 Member Since: 06 Feb 2021 Location: Staffordshire Posts: 2 |
Thank you for the pointer. Found the top right hand hose split, will replace both top hoses immediately and sort the bottom two later. Thanks again |
Sun Apr 18 2021 8:40am |
