Home > General > TDV8 3.6 loss of power
Callyp43
England 2007 Range Rover Sport TDV8 HSE Orkney Grey
2007 tdv8 3.6 98000 miles loss of power. Drive at any speed or load then sudden loss of power, message on dash reads Engine Fault, turn engine off then restart and everything ok but will re occur at any time. No fault codes detected or stored. Suspect a mechanical fault.
Post #612717 Sat Apr 17 2021 11:50am
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Common problem is that the intercooler pipes deteriorate with age, easy and cheap fix so check those.
https://www.island-4x4.co.uk/cooling-heati..._3613.html
Failing that get it scanned for codes.
Post #612719 Sat Apr 17 2021 12:10pm
Does it smoke under load? Black smoke would suggest an intercooler pipe has split. White smoke suggests a turbo failing. If it's the latter, don't drive it until it's looked at because it's not unknown for a turbo failure to stuff enough oil in to the intake system to hydro-lock the engine. 2012 SDV6 - it's missing a couple of cylinders
Post #612721 Sat Apr 17 2021 1:15pm
Callyp43
Thank you for the pointer. Found the top right hand hose split, will replace both top hoses immediately and sort the bottom two later. Thanks again
Post #612751 Sun Apr 18 2021 8:40am
