![]() | Home > General > TDV8 3.6 loss of power |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
Common problem is that the intercooler pipes deteriorate with age, easy and cheap fix so check those.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
Does it smoke under load? Black smoke would suggest an intercooler pipe has split. White smoke suggests a turbo failing. If it's the latter, don't drive it until it's looked at because it's not unknown for a turbo failure to stuff enough oil in to the intake system to hydro-lock the engine. 2012 SDV6 - it's missing a couple of cylinders
Callyp43 Member Since: 06 Feb 2021 Location: Staffordshire Posts: 2 ![]() ![]() ![]() |
Thank you for the pointer. Found the top right hand hose split, will replace both top hoses immediately and sort the bottom two later. Thanks again |
