Home > General > brake booster fails leak test?
mgrover
so ive been getting lean codes for a while now. finally smoke tested brake booster after i figured out how.
vid here
https://photos.app.goo.gl/m6bcYiBAkDcFUzWk6
and the pipe i pumped full of smoke
https://photos.app.goo.gl/d34f2XW7WAuonKXn9
i assume i have to change out the brake booster and its been the cause of the vacuum. i did unplug it and plug the vacuum to plug the leak but the trims were still a bit funny. it might need adaptive trims reset tbf
Post #602749 Tue Aug 04 2020 9:11pm
Well done Thumbs Up
Post #602758 Tue Aug 04 2020 10:07pm
mgrover
Now I just need to learn to bleed brakes :p
Post #602761 Tue Aug 04 2020 10:26pm
You don’t need to.
If you loosen the ABS unit off it’s rubber mounts.
Unbolt the master cylinder 2 bolts it will swing out the way.
To allow booster to be changed once plastic shelf removed and pedal unclipped.
Post #602762 Tue Aug 04 2020 10:40pm
mgrover
Ahh things are gonna get real interesting for me since I've got a busy plastic shelf, the lpg reducer and ecu lives their as well haha
Post #602767 Wed Aug 05 2020 7:57am
It's split into 2 parts.
Can't remember if both parts need to come out
Post #602780 Wed Aug 05 2020 12:02pm
mgrover
So changed everything out, turns out I had a non supercharger brake servo. But I did another smoke test before I installed it, no issues.
After installation smoke pours out the back the same way, am guessing it's not the problem then?
Post #602932 Fri Aug 07 2020 7:59pm
Humm.
I wonder if it’s because your blowing rather than sucking Razz
I guess it needs a hole n the back to work
He cuts t open and the end and explains how it works
Post #602933 Fri Aug 07 2020 8:17pm
mgrover
Aiye I watched both but I just assumed either way it'd be air tight :p I guess when it sucks it'll create an air seal
Post #602935 Fri Aug 07 2020 8:43pm
when the engine has been running for a bit, disconnect the vac pipe. It should hiss for a good few seconds (and loudly) if its good/new
Post #602938 Fri Aug 07 2020 9:11pm
mgrover
My old one hissed for a second at best so I guess we'll see with this new one. Probably means backs to the drawing board on lean codes. Next up, lambda sensors replacement
Post #602940 Fri Aug 07 2020 10:44pm
I thought petrols used an electric pump on the passenger side to generate vacuum anyway ?
So what’s going on ? Where does the vac line go?
Post #602949 Sat Aug 08 2020 9:07am
mgrover
They do yeah, it has a vacuum pump does that mean that it won't affect the amount of oxygen going into combustion?
Am currently trying to still fix my lean codes, lambda sensors seem to be a good shout cause one banks fuel trims is double the others and I've tried all the conventional ways to check
Post #602994 Sat Aug 08 2020 7:00pm
Well I don’t understand how if you connected a smoke machine to the engine it came out the servo ?
Post #602996 Sat Aug 08 2020 7:36pm
mgrover
i connected it to servo directly Razz
Post #602997 Sat Aug 08 2020 8:07pm
