Home > Technical > 2012 (single/ one piece) tailgate opening/ closing problems
Do you manually lift it to the fully open position and then hold it and press the close button until the beep?
Post #649631 Wed Sep 03 2025 8:56pm
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi Col.
Yes, that's what I've tried doing.
Post #649632 Wed Sep 03 2025 8:57pm
pomistea
pomistea wrote:
I'm having a similar problem.
When I press the button either in the car or on the fob, the boot opens about halfway, then stops.
If I press the button a second time, it then continues and opens fully.
I tried resetting by holding the close button when the boot is fully open. I get a beep after about 5 seconds but it doesn't fix the problem.
Any ideas?
Sorry, should have clarified, it's a 2012 RRS LR320.
Post #649635 Wed Sep 03 2025 9:11pm
Just out of interest do you have any fault codes showing, believe it or not there are 31 fault codes listed which are associated with the one piece rear tailgate, just thought it may give a clue if there is.
Is it something that has just started happening or have you replace something prior?
Post #649637 Wed Sep 03 2025 9:21pm
