![]() | Home > In Car Electronics > Is there phone connectivityfor RRS 2006 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
No you need an adaptor.
For the above picture (non amplified, because it has all those green wires) you need: http://www.ebay.co.uk/itm/CT10LR01-Range-R...SwJQdW~nVh or http://www.ebay.co.uk/itm/SOT-082-RANGE-RO...SwMVFXH50G or http://www.ebay.co.uk/itm/SOT-082-RANGE-RO...fzy780uQvQ Not in your country but you get the idea.... Search ebay for "range rover sport parrot" http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0 |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Afternoon,
Yeah that's about it. Good luck.
Got it all wired in. But no power on the parrot. So have to dig out the cigar power..... Queue more you tube searches.
I was thinking the RRS has lots of space for cables compared with other cars.
Thanks. Will do. Once i have power to the parrot unit it will be easier to slide it all into various crevices.
You could get power from the fuse box assuming you can see a path to get it over there.
That looks like what i need, but would need almost a metre long. Maybe 60cm to get from fuse box, through side f centre console into the radio cavity and then plug in.
You just need to by some cable locally for either solution.
Sweet, found the piggy back fuse things locally, just get the wire and necessary clips / plugs from same place.
Just make sure you get the mini version. |
Although the Ebay list says mini and micro so I'm not sure of the correct name now. |
