Home > In Car Electronics > Is there phone connectivityfor RRS 2006
Page 3 of 4 <1234>
No you need an adaptor.
I'll find you one....
Post #497584 Wed Jun 01 2016 6:07pm
Pakolainen wrote:
Further update.
For the above picture (non amplified, because it has all those green wires) you need:
http://www.ebay.co.uk/itm/CT10LR01-Range-R...SwJQdW~nVh
or
http://www.ebay.co.uk/itm/SOT-082-RANGE-RO...SwMVFXH50G
or
http://www.ebay.co.uk/itm/SOT-082-RANGE-RO...fzy780uQvQ
Not in your country but you get the idea....
Search ebay for "range rover sport parrot"
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
Post #497585 Wed Jun 01 2016 6:10pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Excellent. many thanks.
steve 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #497591 Wed Jun 01 2016 7:10pm
Pakolainen
Afternoon,
The ISOT adapter lead arrived today. Time to install the Parrot.
In my minds eye this looks to be simple install, the relevant plugs from the parrot cable harness plug into the corresponding plug on the ISO harness with the matching coloured cables.
And then plug from the Landrover stereo plugs into the only option on the ISO cable and voila. Job done.
Or have i missed out a step.
Cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498114 Tue Jun 07 2016 3:11pm
Yeah that's about it. Good luck.
There is no ignition supply on the RRS plug, so if the parrot requires this you need to get it from the cigar lighter socket plug. (cable colour is usually red or yellow on the ISO adaptors)
Post #498132 Tue Jun 07 2016 5:25pm
Pakolainen
Got it all wired in. But no power on the parrot. So have to dig out the cigar power..... Queue more you tube searches.
Not much space behind the stereo for all these extra cables. Sad
Mazda 3 1.6 2010
Post #498148 Tue Jun 07 2016 8:43pm
I was thinking the RRS has lots of space for cables compared with other cars.
Use the space above if you need to.
Post #498150 Tue Jun 07 2016 8:51pm
Pakolainen
Thanks. Will do. Once i have power to the parrot unit it will be easier to slide it all into various crevices.
The ignition power cable and 12v power cable from th parrot harness are quite short and won't reach all the way down to the cigar lighter area, and that would mean taking apart the centre console??
Not easer to go straight from the fuesbo behind the glove box (not that i know how to)
Steve 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498154 Tue Jun 07 2016 9:10pm
You could get power from the fuse box assuming you can see a path to get it over there.
You can get piggy back fuses for this purpose.
See eBay item eBay Item No. 301803935752 as an example.
Post #498157 Tue Jun 07 2016 9:54pm
Pakolainen
That looks like what i need, but would need almost a metre long. Maybe 60cm to get from fuse box, through side f centre console into the radio cavity and then plug in.
Simple is never so simple. Very Happy 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498158 Tue Jun 07 2016 10:06pm
You just need to by some cable locally for either solution.
Ebay item number eBay Item No. 322048901637
Post #498161 Tue Jun 07 2016 10:24pm
Pakolainen
Sweet, found the piggy back fuse things locally, just get the wire and necessary clips / plugs from same place.
http://www.biltema.fi/fi/Autoilu---MP/Auto...000035590/ 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498165 Tue Jun 07 2016 10:54pm
Just make sure you get the mini version.
Post #498166 Tue Jun 07 2016 11:00pm
Pakolainen
Very Happy Very Happy 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #498167 Tue Jun 07 2016 11:03pm
Although the Ebay list says mini and micro so I'm not sure of the correct name now.
Post #498174 Wed Jun 08 2016 6:55am
Page 3 of 4 <1234>
