Home > Maintenance & Modifications > front end knocking help
simbad111
Hi guys, and girls, i have a 2006 rrs and have got a knoking coming from front end when driving on uneven roads , i know its been asked many times before but what and i looking to change first and would i be able to change the drop links and roll bar bushes myself if you agree with me that it may be the 2 items i mention, any help would be great, if i decide to get them changed at garage what are the cost if anyone knows,
thanks all
Post #423480 Wed May 07 2014 7:18am
Anti-roll bar bushes most likely
Yes, you can do it yourself but it's not easy to get to the bolts
About £200 from a LR dealership, perhaps less if you shop around. 2012 SDV6 - it's missing a couple of cylinders
Post #423482 Wed May 07 2014 7:59am
simbad111
many thanks for the reply I have booked car in to have them changed next week quote £170, hope it does the trick I have also placed order for new drop links which I will change myself,
Post #423563 Wed May 07 2014 7:35pm
rich_z3
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I have the same problem but had it checked today and both lower wishbone bushes are shot Big Cry
Post #423571 Wed May 07 2014 8:25pm
Mister B
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
How much to have them replaced ??
Post #423573 Wed May 07 2014 8:27pm
Mister B
sorry, i'll try again
how much to have them replaced ??
Post #423574 Wed May 07 2014 8:28pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
best way to check anti roll bar rubbers is the disconnect the drop links as it hard to feel any movement with them connected and its only 5 minutes to take them off
Post #423577 Wed May 07 2014 8:32pm
rich_z3
Going to change them myself, got a quote for new wishbones and fitting kit £230 the pair
Post #423578 Wed May 07 2014 8:36pm
simbad111
I will carry on and have roll bar bushes changed firstly due to fact my car as dynamic response roll bar, the drop link I will change myself, I will see what the bushes do if anything, one step at a time,
Post #423685 Thu May 08 2014 6:38pm
That'll be a few hundred pounds depending on whether they're LR / OEM/ pattern parts and who is doing them. Quite often requires the wishbone to be cut off. 2012 SDV6 - it's missing a couple of cylinders
Post #423722 Fri May 09 2014 12:59am
simbad111
All done sounds great now
After changing the anti roll bar bushes and fitting the modified brackets all seems fine now, we did also change both lower suspension arms too, but the problem was the anti roll bushes, the new kit cost £85 and lower arms £240 the pair, hope this helps anyone who get the dreaded knock starting,
Post #429854 Wed Jul 09 2014 7:23am
