![]() | Home > Maintenance & Modifications > front end knocking help |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155 ![]() ![]() ![]() |
Anti-roll bar bushes most likely
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 ![]() ![]() ![]() |
many thanks for the reply I have booked car in to have them changed next week quote £170, hope it does the trick I have also placed order for new drop links which I will change myself, |
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 ![]() ![]() ![]() |
I have the same problem but had it checked today and both lower wishbone bushes are shot |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
sorry, i'll try again
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
best way to check anti roll bar rubbers is the disconnect the drop links as it hard to feel any movement with them connected and its only 5 minutes to take them off |
Going to change them myself, got a quote for new wishbones and fitting kit £230 the pair |
I will carry on and have roll bar bushes changed firstly due to fact my car as dynamic response roll bar, the drop link I will change myself, I will see what the bushes do if anything, one step at a time, |
That'll be a few hundred pounds depending on whether they're LR / OEM/ pattern parts and who is doing them. Quite often requires the wishbone to be cut off. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
After changing the anti roll bar bushes and fitting the modified brackets all seems fine now, we did also change both lower suspension arms too, but the problem was the anti roll bushes, the new kit cost £85 and lower arms £240 the pair, hope this helps anyone who get the dreaded knock starting, |
