Home > Technical > Warning lights come up on dash when i brake??please help
vava voom
United Kingdom 2006 Range Rover Sport 4.4 V8 SE Java Black
Hi guys i need some help please. I have a 55 reg RRS 4.4 Supercharged which has recently been at Hartwell Land Rover in Oxford who have given it a full service and not mentioned any issues apart from my handbrake shoes may be warn.
Anyway after a few days i took it out for a spin and when i put my foot on the brake all the dash lights come on, first transmission fault then hdc fault, then lowered the suspension and took away the special programmes??? now i have to say this never came up before i gave it to land rover and it does not affect the drive at all but it does mean i drive around with the lowered suspension and lights on the dash.
Someone told me to change my battrey and still same issue.....can anyone help please or do i have to take it to land rover to get bent over again?
UPDATE: JUST SEEN ON YOUTUBE SOMEONE WHO HAS THE SAME LIGHTS ON THE DASH WITH SAME ERRORS COMING UP ON THE DASH, USEING A HAWKEYE READER HIS FAULT WAS BRAKE SWITCH/SENSOR SIGNAL, HOW DO I CHANGE THIS SWITH??
Post #326251 Mon Dec 26 2011 7:12pm
Bob.
Check the brake light bulbs before changing switches - a blown filament upsets the system.
Post #326262 Mon Dec 26 2011 9:54pm
vava voom
Would a blown bulb cause all that? having said that i think one of my bulbs is out Thumbs Up
Post #326263 Mon Dec 26 2011 10:01pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Yes it is all connected with thinking that you are braking..check your bulbs first and then your brake light switch, good luck...
Post #326264 Mon Dec 26 2011 10:08pm
vava voom
Thats crazy, i will report back tomorrow. If this sort th eproblem i owe you boyz a drink! Bow down
Post #326266 Mon Dec 26 2011 10:50pm
Bear100
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
my disco 3 had the same issue, fault was due to a cheap bulb that had been fitted on last service, trouble was it was serviced at the same main dealer Embarassed Embarassed
Thumbs Up Range Rover Sport HSE TDV8 MY2010
Discovery 3 HSE 2007
Discovery 2 TD5 (gone)
Discovery 300 tdi
Range Rover Bobtail (gone)
90 hybrid (gone)
Post #326268 Mon Dec 26 2011 11:12pm
vava voom
wow...so i wonder where my £800 went?
Post #326270 Mon Dec 26 2011 11:23pm
Hartwell in Oxford? They don't even have the excuse of a big shiny showroom to pay for. £800 is a ridiculous price for a service. They do charge at £100/hr plus parts though... 2012 SDV6 - it's missing a couple of cylinders
Post #326275 Tue Dec 27 2011 9:47am
vava voom
Yes Hartwell in Oxford, ok changed the bulb and all lights are now off with no issues when brakeing! It amazes me how something so simple can affect the whole car!
Thanks for your help guys Thumbs Up
Post #326365 Wed Dec 28 2011 11:03pm
vava voom
Hi Guys
2 days and no lights on the until today again same message and then all lights come up on the dash, any suggestions?
Post #326538 Fri Dec 30 2011 11:23pm
toeuk1
Hi Vava, did you get it sorted yet? I recently had the same problem. It was cured by fitting a new brake pedal switch. Cheers,
Tony. Thumbs Up
Post #332928 Sat Feb 18 2012 11:09am
