![]() | Home > Technical > Warning lights come up on dash when i brake??please help |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Check the brake light bulbs before changing switches - a blown filament upsets the system. |
vava voom Member Since: 20 Oct 2011 Location: oxford Posts: 7 ![]() ![]() ![]() |
Would a blown bulb cause all that? having said that i think one of my bulbs is out |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Yes it is all connected with thinking that you are braking..check your bulbs first and then your brake light switch, good luck... |
Thats crazy, i will report back tomorrow. If this sort th eproblem i owe you boyz a drink! |
Bear100 Member Since: 02 Jun 2011 Location: South Wales Posts: 106 ![]() ![]() ![]() |
my disco 3 had the same issue, fault was due to a cheap bulb that had been fitted on last service, trouble was it was serviced at the same main dealer |
wow...so i wonder where my £800 went? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
Hartwell in Oxford? They don't even have the excuse of a big shiny showroom to pay for. £800 is a ridiculous price for a service. They do charge at £100/hr plus parts though... 2012 SDV6 - it's missing a couple of cylinders
Yes Hartwell in Oxford, ok changed the bulb and all lights are now off with no issues when brakeing! It amazes me how something so simple can affect the whole car!
Hi Guys
toeuk1 Member Since: 18 Sep 2011 Location: UK Posts: 29 ![]() ![]() ![]() |
Hi Vava, did you get it sorted yet? I recently had the same problem. It was cured by fitting a new brake pedal switch. Cheers,
