![]() | Home > General > L494 drivers heated seat not working |
Ambit Member Since: 07 Oct 2024 Location: Wales GB Posts: 6 ![]() ![]() ![]() |
The car does not have cooled seats only heated seats |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
If you had a multi meter you could test the resistance of the heating element. But it would appear you have found the issue, that would only confirm it. 2015 4.4 Autobiography
Yes going to get a test meter on it and test continuity etc when it stops bucketing down here - hopefully over the next few days |
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
Did you manage to find the fault, and repair it? I have the same issue, and looking for hints.
Yes mine has no continuity so will be stripping the seat to check for any broken wires - I found the following info on the web regarding the seat and heated pads maybe useful to us ..
craigbisby1 Member Since: 22 Oct 2025 Location: Llandudno Posts: 1 ![]() ![]() |
Did you ever get this sorted? I'm having the same problem with mine |
No need to get this done now it’s getting colder again! |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 321 ![]() |
Had the same issue a few years ago - will be the heating seat pad - only way to fix it is to fit a new one.
