Home > General > L494 drivers heated seat not working
Ambit
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
I have a 2014 RRS
Driver heated seat base and back sections do not heat at all since I’ve bought the car. Passengers and rear heated sets all work fine.
Yesterday I checked all fuses checked all visible cabling for any obvious damage none found. Removed seat back cover all looked ok. Swapped seat module over from passenger seat - re tested and still the same no heat. So now I’ve run out of things to test - I’ve added some pics of the back of the seat with the seat back off does this all look ok?
Post #644595 Mon Oct 07 2024 5:42pm
Ambit
Post #644596 Mon Oct 07 2024 5:43pm
Ambit
The car does not have cooled seats only heated seats
Post #644767 Wed Oct 16 2024 5:52pm
PC76
If you had a multi meter you could test the resistance of the heating element. But it would appear you have found the issue, that would only confirm it. 2015 4.4 Autobiography
2010 3.0 HSE 162K - Gone
Post #644797 Sun Oct 20 2024 8:10am
Ambit
Yes going to get a test meter on it and test continuity etc when it stops bucketing down here - hopefully over the next few days
Post #644804 Sun Oct 20 2024 1:05pm
Dobby
Did you manage to find the fault, and repair it? I have the same issue, and looking for hints.
Cheers MY15.5 HSE
MY13 110
MY87 90 (ex-mod) (for sale)
Post #645808 Sun Dec 15 2024 9:49pm
Ambit
Yes mine has no continuity so will be stripping the seat to check for any broken wires - I found the following info on the web regarding the seat and heated pads maybe useful to us ..
Post #645809 Mon Dec 16 2024 8:37am
craigbisby1
Did you ever get this sorted? I'm having the same problem with mine
Post #650259 Wed Oct 22 2025 4:19pm
Ambit
No need to get this done now it’s getting colder again!
Post #650265 Wed Oct 22 2025 9:56pm
Karlp606
Had the same issue a few years ago - will be the heating seat pad - only way to fix it is to fit a new one.
Its a DIY job if you get the seat out on a workbench etc
Post #650293 Thu Oct 23 2025 12:31pm
