![]() | Home > Technical > Suspension problem |
rhumba Member Since: 10 Jun 2024 Location: Brazil Posts: 3 ![]() ![]() |
I am sorry to hear about your problems...
domewing Member Since: 30 Sep 2025 Location: New Forest Posts: 4 ![]() ![]() ![]() |
Hi All,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5146 ![]() ![]() ![]() |
Is there a possibility that second code is actually C1A04 as on a L320 that points to a R/H/F height sensor fault not sure on a L494 though, I think there should be another two digits go with both those fault codes which may narrow it down a bit more, is there anything showing on the 4x4 screen height wise?
Hi Col - thanks for that, but its definitely a 4 on that code. Only have Carsoft v1 so presumably don't get the full code with that!
I think I would start by checking around the height sensor first for anything broken or damaged wiring etc. If all appears OK I would think a height calibration check would be a good place to start. I don't know if the front height sensors are the same both sides on the L494, but if they are could swap left to right to see if fault changes position, only a suggestion as may not prove anything but would only cost a bit of time rather than throwing money at it without knowing exact fault.
Thanks Col - that's great advice.
