![]() | Home > General (L494) > Sunroof drains |
Ironhorse Member Since: 21 May 2024 Location: bromsgrove Posts: 34 ![]() ![]() |
l494 only got back drains
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 133 ![]() ![]() |
Sounds like a plan. Not sure whether to simply paint it or do the stainless insert trick - tempted with the latter as it's quick, cheap and should leave no room for doubt, but as you say, testing and clearing the drains is equally important.
rivet Member Since: 09 Jun 2025 Location: Nor'east Posts: 24 ![]() ![]() |
Once the mouldings or finishers either side of the sunroof are removed you should have complete access to the roof ditch and be able to see all.
+1 on that question.
I removed the outer trims so I could fit the roof rails which are now in place. The fitting of the roof rails went well but I did have new finishers to fit into place so that was not a problem.
I've been out to have a proper look at mine.
They just pull off quite easily
Thanks. Much appreciated.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1919 ![]() ![]() |
https://www.rangerovers.net/threads/have-y...st-2393113 2026 P460e Autobiography on order
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 315 ![]() |
Thanks Jim - Was gonna post this up earlier - Ive done my own range rover and 3 others now so if anyone needs a hand or advice with this issue drop us a message. |
There's some brilliant ways for fixing it. Those brass fittings would be my first choice if I had a snapped drain.
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 259 ![]() ![]() |
I assume these inserts are suitable and they look to be longer, thus giving more support, than the plastic ones?
I think so.
Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 7 ![]() ![]() |
@ironhorse when you say 2 rear drains do you mean those over each B Pillar please? |
