Home > General (L494) > Sunroof drains
41jules1967
Sunroof drains
I make a point of reading up on known issues and doing preemptive maintenance where possible. So I’m aware of the tank guard and have lanoguarded mine but this one had passed me by until I saw this.
?si=rPX_ARqobxTHvYev
Maybe it’s because the opening roof is less common on the 494 that I’d not spotted it.
Anyway, I’m going to look at epoxying in some 10mm stainless inserts which sound like a cheap and simple way of avoiding the problem in the first place.
One question is, nobody mentions the front drains. Do they not suffer? 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #649966 Sun Sep 28 2025 7:57am
Ironhorse
l494 only got back drains
well that's all i could find on mine
passenger side was blocked with leaves and stuff but looked good after i cleaned it out.
got a little bottle brush down it,couple of coats of rust eater then treated it with stone chip
all good Thumbs Up 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #649969 Sun Sep 28 2025 4:07pm
41jules1967
Sounds like a plan. Not sure whether to simply paint it or do the stainless insert trick - tempted with the latter as it's quick, cheap and should leave no room for doubt, but as you say, testing and clearing the drains is equally important.
Haven't looked at mine yet. Got a cheap amazon endescope camera coming for my iphone to make it a little easier to see. 2021 L494 D300MHEV Autobiography
Post #649970 Mon Sep 29 2025 6:55am
rivet
Once the mouldings or finishers either side of the sunroof are removed you should have complete access to the roof ditch and be able to see all.
I do wonder if they are reusable and go back on with no problems? As long as the clips that hold it in place don't fail I see no reason why not.
How did they go back on for you Ironhorse?
Post #649971 Mon Sep 29 2025 7:32am
41jules1967
+1 on that question.
From what I can see, there are 2 trims side by side.
The first outer one is what you remove to fit roof rails - there's a powerful-uk video showing pulling those off but the inner one for the sunroof, I can't find a single thing on. Some show it already removed but how you do that I have no idea. Does it just pull up like the other one or are there bolts? 2021 L494 D300MHEV Autobiography
Post #649975 Mon Sep 29 2025 1:14pm
rivet
I removed the outer trims so I could fit the roof rails which are now in place. The fitting of the roof rails went well but I did have new finishers to fit into place so that was not a problem.
Looking at the original finishers I removed for the roof rails left me wondering if I could have just put them back into position as was? I doubt it as there are adhesive spacers and other adhesive strips that were no longer usable. In other words the original trim pieces would not have refitted without additional parts ensuring the fit was as intended.
So, I am reluctant to remove the two sunroof trims in case I cannot refit them as is without getting the parts required to do that.
Post #649976 Mon Sep 29 2025 3:01pm
41jules1967
I've been out to have a proper look at mine.
There's no visibility at all, with just the roof open and looking at the trims, I'm not convinced I'd want to mess with the one that covers the drain unless someone can show me a video on removing it.
I bought one of those cheap endoscope cameras that connects to your phone from Amazon - bloody thing didn't work most of the time (it's going back) but in the short moment I got a picture out of it, I managed to catch a glimpse of the drain and .. there's signs of rust. Not much yet, but enough to tell me it's going to be a problem at some point if I don't do something about it.
For access - it's either the trim or else remove the sliding glass panel. Problem is, I can find no info on how to do either. Nothing on youtube and nothing on google.
Does anyone have a workshop manual that covers this?
Update:
L405 but the same thing. Looks like you just have to be brave.
&t=94s 2021 L494 D300MHEV Autobiography
Post #649979 Mon Sep 29 2025 4:20pm
Ironhorse
They just pull off quite easily
bit of a loud snap sound but all OK
Start from the front with boot open,
Just snap back into place when finished, there are 2 rubber pads where the sticky stuff is left on the roof I just put some silicone on them and not had a issue since 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #649981 Mon Sep 29 2025 4:54pm
41jules1967
Thanks. Much appreciated.
I’ll try to write a full how-to when I do it. 2021 L494 D300MHEV Autobiography
Post #649982 Mon Sep 29 2025 4:57pm
jimbg
https://www.rangerovers.net/threads/have-y...st-2393113 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #649983 Mon Sep 29 2025 6:33pm
Karlp606
Thanks Jim - Was gonna post this up earlier - Ive done my own range rover and 3 others now so if anyone needs a hand or advice with this issue drop us a message. Thumbs Up
Easy fix - You dont need to take the full headliner down you can take the inner weather strip out and unscrew the passenger ceiling light then pull the headliner down and get your hands into wear the drain connects to the rubber drain tube.
You can buy some copper fittings now also ;
https://www.aliexpress.com/p/tesla-landing...nkQAvD_BwE
Or check BQ for a similar fitting.
Post #649992 Tue Sep 30 2025 10:53am
41jules1967
There's some brilliant ways for fixing it. Those brass fittings would be my first choice if I had a snapped drain.
The focus of my post is slightly different though.
Fixing once it's gone is likely to be a headache, especially given the potential to destroy the amplifiers.
This forum must be full of people with affected cars, like mine, that simply haven't failed yet. It's them I'm really hoping to target.
My last car was a Jag XF. That has a problem where the rear crash bar rots out and dumps the exhaust on the floor. I sort-of knew about it, but didn't worry myself until one day i came out to find my exhaust on the floor. What followed was 2 months of hassle and considerable expense.
Point is, had I just thought about it for a minute, I could have spent a couple of hours removing my, at the time, slightly rusty but sound crash bar, rub it down, drown it in hammerite and pop it back. Problem solved. No 2 months finding a replacement and no £400 bill.
So it is with the drains. There's some clever people like you guys that sound to have fixing it down to a T but truth is, (and correct me if you disagree) epoxying an insert into the not-yet-rotted-out pipe, should mean that the problem stops getting any worse, the pipe never snaps and you never have to bail out your amplifier and dry out the carpet.
I want to get that message out to all the people with 494s (and 405s)who have sunroofs that for an hour of effort and less than £10 can avoid the whole nightmare in the first place.
To be fair, it's a service all good specialists should offer! 2021 L494 D300MHEV Autobiography
Post #649993 Tue Sep 30 2025 12:30pm
RRT
I assume these inserts are suitable and they look to be longer, thus giving more support, than the plastic ones?
https://www.screwfix.com/p/hep2o-smartslee...pack/6398f MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #649998 Tue Sep 30 2025 4:48pm
41jules1967
I think so.
I bought some similar ones from eBay. My only hesitation on those is the shape of the head which I’m not sure will be so easy to seal but I imagine I’m overthinking it. 2021 L494 D300MHEV Autobiography
Post #650004 Tue Sep 30 2025 5:32pm
Ade RRS
@ironhorse when you say 2 rear drains do you mean those over each B Pillar please?
Post #650007 Tue Sep 30 2025 8:18pm
