| RRSPORT.CO.UK | ||
|  | Home > Wheels & Tyres > How to tell which locking wheel nut |
| Jon w Member Since: 21 Jul 2025 Location: Mold North Wales Posts: 4    |
 I have looked at the search function and not found an answer so hence this post
|  Mon Sep 29 2025 11:36am |
| T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 106      | If there is a locking one, then it will be distinctively different so you may not have any fitted.
|  Mon Sep 29 2025 3:46pm |
| T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 106      | Any LR dealer should have a full set of keys to get your locking wheel nuts off (providing they're original ones).  If they're aftermarket, it could be a real PITA as gogsy says.
|  Mon Sep 29 2025 4:42pm |
| Jon w Member Since: 21 Jul 2025 Location: Mold North Wales Posts: 4    | Thanks the standard wheel nuts are fine, I have cracked them off with a 23mm 6 point socket and tightens them up again to apply force in the hope it makes undoing the locking wheel nut easier.
|  Mon Sep 29 2025 7:42pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | If you can get just one of the locking nut's off, if you look at the face of the rotating washer the code for the locking nut is stamped on it, perhaps you could then get the correct key for the other three off fleabay or something.
|  Mon Sep 29 2025 7:49pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | I think I used a 27mm 12 point to get mine off, never to return. Replaced all with Gorilla one piece lug nuts. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Wed Oct 01 2025 4:37am |
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586    | Hi,
|  Wed Oct 08 2025 6:36pm |
| Posting Rules
