![]() | Home > Wheels & Tyres > How to tell which locking wheel nut |
| Jon w Member Since: 21 Jul 2025 Location: Mold North Wales Posts: 4
I have looked at the search function and not found an answer so hence this post
| T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 106
If there is a locking one, then it will be distinctively different so you may not have any fitted.
Any LR dealer should have a full set of keys to get your locking wheel nuts off (providing they're original ones). If they're aftermarket, it could be a real PITA as gogsy says.
Thanks the standard wheel nuts are fine, I have cracked them off with a 23mm 6 point socket and tightens them up again to apply force in the hope it makes undoing the locking wheel nut easier.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
If you can get just one of the locking nut's off, if you look at the face of the rotating washer the code for the locking nut is stamped on it, perhaps you could then get the correct key for the other three off fleabay or something.
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 524
I think I used a 27mm 12 point to get mine off, never to return. Replaced all with Gorilla one piece lug nuts. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586
| All times are GMT |
