Home > My Range Rover Sport > L320 Changing the rear anti roll bar ace unit
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Can anyone tell me what is involved in changing the rear anti roll bar with an ace unit, I have just changed my front ace pipes, and I had also ordered the back pipes but have noticed the back ACE unit is leaking badly, I have got a replacement bar, would like to know how hard a job it is going to be.
Thanks for any help you can provide me with Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #649801 Sun Sep 14 2025 9:16pm
Disco_Mikey
Rear bumper off
Disconnect rear body dampers
Separate body from chassis by 5-6 inches or so
Gives just enough room to slide the bar out 1 side
Post #649803 Mon Sep 15 2025 8:04am
Frax
Thank you, do you just have to remove the two back body mounting bolts. I have not got to it yet, all front pipes are almost on but can't get the one that looks like some sort of quick connect, I have pulled it pushed it and twisted it but it doesn't want to come apart. how the flip do they separate.
https://www.rrsport.co.uk/gallery/albums/u...0pipe.jpeg Lot of Landcruisers now sold
Defender 300tdi 90
Post #649806 Mon Sep 15 2025 12:21pm
gogsy1956
Does it actually come apart ?,,, I maybe wrong but that looks like a connection from hard pipe to Flexi which I thought were permanent. I understood that the front pipes came with 2 or 3 Flexi pipes attached. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #649812 Mon Sep 15 2025 7:20pm
Frax
It's hard to see but the part at the bottom of the picture is the conversion from rubber hose to steel, the
next part which is straight is the conversion section which has a rubber seal where it ends, the next section with the step change in size is the part that plugs into the coupling then there is a bracket.
I have the new part as I bought a full set of front pipes, 2 of which are steel and the other 2 are part rubber, one goes to the fill pot in the engine compartment and it's just a push on and secured with a pipe clip, the other is the pipe in question which I thought would be easy but I can't get the old one off
The new end has what looks like an internal C style clip about 5mm in and you can see at the very end what looks like a "O" ring, to me it looks like the new pipe end should just push on and seal against the "O" ring and the "C" clip just keeps it in place. Lot of Landcruisers now sold
Defender 300tdi 90
Post #649814 Mon Sep 15 2025 7:46pm
A4j1s0
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Evening Frax.
Im in exactly thre same position as you.
Have cut the old flexible pipe down to the crimped fitting and made an adaptor to go in a slide hammer.
The fitting rotates easilly but will not pull of the steel bend.
The internal clip looks the same design that holds a drive shaft to a CV joint.
Post #649815 Mon Sep 15 2025 9:16pm
Disco_Mikey
The pipes push together, and the black collar slides into the joint, releasing the C clip. Quite fiddly until you get used to them Thumbs Up
Post #649816 Mon Sep 15 2025 9:30pm
Frax
Hi, I was thinking of cutting it along the edge with a dermel and then try to split it, the dremel sadly is a bit short, your sliding hammer might be better but was not sure if it would damage the part that slides in, I have hunted but cannot find the answer to this fitting, it's a right pain in the ****, please let me know how you get on, I won't get back to mine until Wednesday, my one also spins easily - it's a pain in the rear end Lot of Landcruisers now sold
Defender 300tdi 90
Post #649817 Mon Sep 15 2025 9:31pm
Frax
Hi Disco Mikey thanks for the reply, I have not seen a black part, does it slide into the fitting to open the "C" clip where the rubber seal is.
I thought they just pushed together and locked into position.
Is my black bit on my one just rusty Lot of Landcruisers now sold
Defender 300tdi 90
Post #649818 Mon Sep 15 2025 9:35pm
Disco_Mikey
It's not apparent at the moment, but the seal is a metal clip, covered in rubber. The seal/clip slides inside the pipe fitting, and releases the internal C clip. Does take a few goes to release, as its fiddly
I've a spare ARC pump on the floor at work, I'll see if I can grab a pic today Thumbs Up
Post #649821 Tue Sep 16 2025 6:27am
Frax
Your help is much appreciated; I did see something on another forum where they used a U shaped tool but it was not clear where it went, I did make one and tried to use it to wedge the fitting apart but had no luck.
What do you use to push the clip into the fitting, I would rather remove it the right way even if it is fiddley.
Picture would be great if you can get one Bow down Lot of Landcruisers now sold
Defender 300tdi 90
Post #649822 Tue Sep 16 2025 10:04am
Frax
Hi I would like to say I had a few days off but no, since I was having luck with the front I might just concentrate on the back (some job) Removed the back bumper, spare and back wheels and removed 4 body mount bolts but this did not get me enough room to remove the roll bar so removed another 2 and was jacking the body up using the strengthener where the spare sits, this time it was almost there but not quite so used the scissors jack at the rear body point where the bar sits and got it out that side with a bit of a help with another jack lifting the wheels to get the arms out, getting the ace pipes out was easy, just cut them, getting the new ones was a bit of a struggle really - the 6mm holding the bracket on was not easy but got it out, getting the new one in was also a struggle along with the bracket with the 6mm nut, again got there, did get it all back together, still got the bumper to go on.
The front quick connects was next, used the tool I made and a long strong screwdriver to help push my tool (should have named it something else) up against the release collar which was just silver in my case, and it popped right off, I take it I was just lucky because I found it easy, saying that the rubber was removed and the tool I made was a good fit, do you need to bleed the system as a new filter was fitted, I did add 1lt of fluid and ran it for a while till I refitted the wheels, lots of alarms but switched it of after about 30 min and restarted and they were all gone.
Knowing where to place the tool I made was a great help, image of the said tool Lot of Landcruisers now sold
Defender 300tdi 90
Post #649919 Mon Sep 22 2025 8:32pm
