![]() | Home > Technical > 22 inch Tyres |
The Range Rover Member Since: 25 Jan 2010 Location: Whitburn Posts: 54 ![]() ![]() ![]() |
Hi All
Shadwell Member Since: 10 Oct 2024 Location: South coast Posts: 16 ![]() ![]() ![]() |
Mitchelin is my preference on my car not cheap but you get what you pay for Well hear I am |
RallyeSport Member Since: 20 Jun 2024 Location: Gloucester Posts: 110 ![]() ![]() ![]() |
On my 22" Overfinch Elara's after having them refurbished at Wheelmania in Evesham - they recommended Falken FK510 SUV, they are nice and quiet tyres and are good in wet and dry, not that I drive the car like I stole it mind you.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Shortly after I first bought my RRS, I put new tyres on all round. I liked the look of the tread pattern on some Uniroyals (supposedly very good in the wet)and so fitted them. I then have an issue with steering wander and spent a fair amount of time and money getting the car 4 wheel aligned (twice!) and then put it into my local indie a few times to try and sort the problem. All to no avail. when the time came to replace the Uniroyals I decided to go back to the factory fitted Pirellis. Problem solved! No more wandering. Very weird but I assume the RRS didn't like the tread pattern...
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 147 ![]() ![]() |
I’ll always fit what came on my RRS when new which are Pirelli Scorpion Verde’s They last 35k miles and if you shop around you can get them for around £800 for 21” which I think is an utter bargain.
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 147 ![]() ![]() |
It's amazing the difference extra inch makes.
The first place I looked, as I got mine from here when shopping around:
I usually look at blackcircles, have had success with tyreshopper (national tyres), Halford and when they have what you need, Costco are brilliant! 2021 L494 D300MHEV Autobiography
Actually, we’ve only just joined Costco and their prices seemed very good for tyres. Wife’s Evoque will need doing next, so I’ll be definitely having a look there. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
I used Camskill Tyres a few times when still in the U.K. I see they have the 22" Verde all season NCS tyre at £217.00 each the 21's slightly less, of course there is still the additional fitting and balance cost.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
The question of premium vs saving money on "cheap" tyres comes up from time to time. The use of the tyre label rating is interesting as it is intended to show which tyre is better. But it only really applies within the tyre manufacturer's range of tyres. A wet "C" from one maker will perform differently to a wet "C" from another when tested against each other.
I agree with 99% of what you say, except
If all tyres are tested equally against a given data point, then all tyres given a particular rating ought to perform the same on a car. But tyre testing of various tyres back to back shows that some of these tyres perform much worse than others from other manufacturers. Which suggests that some manufacturers might be designing to the test and others are designing to reality and then is showing up well in the test.
