Home > In Car Electronics > TST Instrument Cluster Retrofit
Page 6 of 6 <123456
durgapal
Its diesel and the dial says - Diesel.
Post #648431 Wed Jun 18 2025 1:43pm
Timmo1710
2010 Range Rover Sport TDV8 Autobiography Santorini Black
It still needs changing to gauge variant 2 so the rev gauge only goes to 6000rpm with a redline at 4000rpm rather than going to 8000rpm with a redline at 6000.
It can be done by editing the CCF in SDD.
I can help if needed 👍
Should look the picture below:-
Post #648432 Wed Jun 18 2025 2:00pm
durgapal
It can be done.
I am not worried about that as I am never going to rev that high in the LR. For that I have a motorcycle Smile
May be when I have some spare time...
Post #648433 Wed Jun 18 2025 2:22pm
Timmo1710
It really does finish the job off and doesn’t take that long to do 👌
Post #648437 Thu Jun 19 2025 12:30am
durgapal
It does. Smile
Post #648440 Thu Jun 19 2025 9:39am
Dutchviking
Norway
I am trying to build a CAN gateway that maps the applicabe CAN IDs from Discovery 3/(RRS MK1) on the 29 bits CAN bus to the 11 bits CAN bus that the TFT IPC is using. This way also the D3/RRS can use this fantastic upgrade. Nobody here that by any change has sniffed both CAN buses of both Range Rover and Discovery3/RRS for the applicable CAN IDs so I can try these in the Arduino scetch I am running?
Post #648827 Mon Jul 14 2025 6:07pm
Timmo1710
I’d be really interested in watching this progress and possible purchase one or build my own?
Post #648828 Mon Jul 14 2025 6:27pm
Dutchviking
Norway
got everything connected, correct CAN scetch running, original IPC disconnected however TFT does not turn on. Next step is to read VIN and milage etc as described so kindly by TheWojtek as a reference:
- The VIN is located at position 0A8: copy 17 bytes of the VIN from old cluster file to new cluster file.
- Dash type is located at position 0C0: copy 16 bytes*
- Mileage is located at position 784: copy 16 bytes*
- Immobiliser is located at position 7E8: copy 31 bytes (right to the end of file)
I will try this first on a used Discovery 4 IPC as its eeprom is readily accessable. Maybe the Immobilizer routine with wrong VIN and Milage in the D4/RR IPC prevents the IPC to respond to CAN messages and turn on
Post #648829 Mon Jul 14 2025 7:34pm
Timmo1710
When I was converting mine I forgot to put the dash model in and it failed to switch on.
Do you need a copy of an L322 TFT eeprom file?
Post #648830 Mon Jul 14 2025 7:43pm
Dutchviking
Norway
many thanks for the offer but have the xhorse vvdi2 and vvdi prog so will read and modify the tft eeprom when the D4 IPC proof of concept works. D4 and 2012 Range Rover share the exact same pinout of the IPC connector.
Post #648831 Mon Jul 14 2025 8:19pm
Dutchviking
Norway
some progress and nice to know for others is that the D3 milage is held in IC9, EEPROM ST35080VP. The milage is stored as is, not encrypted like with the Discovery 4. mine had 236862 Km at time of IPC removal. put that in a decimal to hex converter and you get 39D3E. At position A0Dh the value is stored as 039D3E and only once. Not repeated 5x as with Discovery 4. And no VIN in this file.
Post #649113 Sun Jul 27 2025 2:22pm
TheWojtek
Whoa, getting this cluster to work in a pre-facelift RRS/Disco3 is just some next-level engineering. There was a guy in Russia who had a plug-and-play CAN converter done for this very application, but not doing business with Russia and he vanished anyway, so @Dutchviking is the only hope for prefacelift folks. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #649122 Mon Jul 28 2025 10:30am
Dutchviking
Norway
the CAN gateway is working and I already sniffed my own D3 and a visiting Discovery 4 as CAN messages between both cars are different so we need to map D3 messages to become D4 messages that the cluster understands. And then there is the immobilizer problem. Copying Milge and VIN to my D4 cluster eeprom is not enough. Panel does not even turn on. I have to find the immobilizer code in the D3 eeprom dump and copy that to the D4 eeprom and see if that does the trick.
Post #649123 Mon Jul 28 2025 10:51am
Dutchviking
Norway
Ordred a 2012 Range Rover ECU kit and will build a rig to be able to sniff the can bus as I do not have a Land Rover with an 11 bits can bus at hand. When can bus ids for ignition on, door open, lights, turn signal, hazard lights etc etc are known I can build a can id mapping between Discovery 3 29 bits and Range Rover 11 bits, to wake-up the IPC and show relevant information on it. Things like RPM and speed I already found on other forums.
Post #649372 Sat Aug 09 2025 2:56pm
Page 6 of 6 <123456
