![]() | Home > In Car Electronics > TST Instrument Cluster Retrofit |
durgapal Member Since: 29 Apr 2025 Location: Midlands Posts: 6 ![]() ![]() |
Its diesel and the dial says - Diesel. |
It can be done.
Timmo1710 Member Since: 16 Jun 2025 Location: United Kingdom Posts: 9 ![]() ![]() |
It really does finish the job off and doesn’t take that long to do 👌 |
It does. |
Dutchviking Member Since: 04 May 2015 Location: Oslo Posts: 3 ![]() ![]() |
I am trying to build a CAN gateway that maps the applicabe CAN IDs from Discovery 3/(RRS MK1) on the 29 bits CAN bus to the 11 bits CAN bus that the TFT IPC is using. This way also the D3/RRS can use this fantastic upgrade. Nobody here that by any change has sniffed both CAN buses of both Range Rover and Discovery3/RRS for the applicable CAN IDs so I can try these in the Arduino scetch I am running? |
I’d be really interested in watching this progress and possible purchase one or build my own? |
got everything connected, correct CAN scetch running, original IPC disconnected however TFT does not turn on. Next step is to read VIN and milage etc as described so kindly by TheWojtek as a reference:
When I was converting mine I forgot to put the dash model in and it failed to switch on.
many thanks for the offer but have the xhorse vvdi2 and vvdi prog so will read and modify the tft eeprom when the D4 IPC proof of concept works. D4 and 2012 Range Rover share the exact same pinout of the IPC connector. |
