Home > In Car Electronics > Changing headlight direction for Europe
Flumpet
Range Rover sport hse 2014.
I’ll be off to France in a few weeks and according to the handbook I can change the direction of the headlights for this. The manual suggested I do this from the in-car driver settings, but I can’t find anything. (I don’t know if it’s related, but I can’t find the automatic headlight high beam assist function either that according to the manual my car should have…)
Is it something that needs to be enabled /programmed to be able to alter?
Post #649015 Wed Jul 23 2025 2:16am
Pistnbroke
on mine you took out the headlight and moved a lever on the back. I put a length of welding wire on the lever so I could do it without taking out the light ...push and pull on the wire ( two lev
ers to lift to remove the light unit)
 Always listen to old people or when they die you will live on in ignorance.
Post #649018 Wed Jul 23 2025 8:03am
scrumps
If you can change the headlight setting, it is in one of the menus on the dash.
It isn’t the headlights (from memory) but “Drive on the left (or right)”
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #649019 Wed Jul 23 2025 8:20am
Pistnbroke
Easy to wip out one of the headlights and see if it has a lever ..if not its in the dash menu Always listen to old people or when they die you will live on in ignorance.
Post #649020 Wed Jul 23 2025 8:28am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Not very easy to remove the headlamps on MY2014, it's a bumper off job.
The headlights are asymmetrical so need no adjustment, however you need to change the high beam assist setting from drive on right to left, so it detects oncoming traffic.
Post #649021 Wed Jul 23 2025 10:45am
Pistnbroke
More junk information ....Asymetrical means the beam is biased to shine up the LH kerb. so if you go to drive on the right the dip beam goes into the oncoming drivers eyes.
Park in front of your garage door and you will see the light goes to the left.
The main beam does not change dependent on the side of the road because you are supposed to turn it off when vehicles approach Always listen to old people or when they die you will live on in ignorance.
Post #649022 Wed Jul 23 2025 11:14am
jimbg
It is a flat beam and needs no adjustment apart from the auto high beam assist option.
It was certainly on 2015 cars onwards.
AUTO HIGH BEAM [G1814328]
This feature of the Xenon lighting automatically selects and deselects the high beam, under specific conditions of road lighting and in the absence of other vehicle’s lights. The system is only active when the ambient light drops below a predetermined level.
NOTE:
It is not recommended that Auto high beam is used while driving off road.
For Auto high beam to become operational, the lighting control must be in the AUTO position (5), with dipped beam headlamps selected.
The Instrument panel warning lamp illuminates when Auto high beam is selected. See AUTO HIGH BEAM (GREEN).
Auto high beam will activate only when the vehicle's speed exceeds 40 km/h (25 mph). The system will deactivate when the vehicle's speed drops below 24 km/h (15 mph).
To manually select high beam, move the control to the high beam position, as normal. To return to Auto high beam, move the control back to the central position.
To manually override to dipped beam from high beam, pull the control to the flash position (2) and Auto high beam will be cancelled. To return to Auto high beam, push the control to the high beam position (1) and then return it to the central position.
To turn off Auto high beam, turn the lighting control from AUTO to headlamps.
This feature can be disabled/enabled via the Vehicle Set-up menu. See INSTRUMENT PANEL MENU.
The following may affect the operation of Auto high beam:
Highly reflective road signs.
Dimly lit road users, for example, cyclists or pedestrians.
Adverse weather conditions, for example, rain or fog.
Dirty or obscured sensor.
Dirty, damaged, or misted windscreen.
Oncoming vehicles partially obscured by a central highway barrier. 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #649023 Wed Jul 23 2025 11:35am
Pistnbroke
well if its a flat beam its not asymmetrical Always listen to old people or when they die you will live on in ignorance.
Post #649026 Wed Jul 23 2025 12:07pm
2 RRS
Aren't you the user who couldn't change a crank sensor, so sold the old bus, so much for mechanical aptitude if you think 2014 headlights are an easy pop out job like on your old L320.
Post #649028 Wed Jul 23 2025 12:52pm
Pistnbroke
could you lift the gearbox off at 80..?? Always listen to old people or when they die you will live on in ignorance.
Post #649029 Wed Jul 23 2025 1:12pm
Flumpet
Thanks. I’ll take a look at the lights.
Is it really a bumper off job…? (Looks like I don’t have /can’t find the high beam assist)
I’ll definitely be looking for a fix to alter that. Can’t be doing that every time I go abroad… 🤨
Post #649043 Thu Jul 24 2025 8:21am
Was high beam assist standard or a option on the L494.
Post #649049 Thu Jul 24 2025 8:57am
2 RRS
It was an option on MY2014 dynamic spec, not sure about other specs or years.
Post #649050 Thu Jul 24 2025 9:16am
2 RRS
I'm afraid so, bumper off, so front section of wheel arch liner too. You still have lights that are OK for Europe, the high beam assist is merely to switch automatically between high and dipped beam, it needs to be adjusted for continental roads to detect oncoming traffic and dip accordingly.
All L494 headlights are OK for UK or continental roads without adjustment, there is no adjustment lever fitted to any model as there was on the L320.
In a nutshell, you're good to go as is.
Post #649052 Thu Jul 24 2025 9:22am
Flumpet
Oh great! Thanks.
Post #649070 Thu Jul 24 2025 8:55pm
