Home > Faults & Fixes > 2006 RRS 2.7 gurgling when holding brake pedal
jpvd
Hi All...just after some advice
Upon holding the brake pedal i am hearing a gurgling from behind the dash. Have done some research and there was a recall some years ago for updated vac lines and possibly servo replacement to stop oil getting into the brake servo and causing reduced braking performance and noises...
i have checked and i believe the work ahs been done, as there are two vac hoses, with a type of valve, but not 100% sure. I have checked the vin online and it doesn't say it is outstanding, but still not sure...
Therefore i am going to give Land Rover a call tomorrow and double check - but if the work was done and there is now still an issue, will Land Rover still fix the issue for free under this recall even though its years later? - are they still liable for past recalls if the problem which was fixed, has reoccured?
many thanks
paul
Post #648957 Sun Jul 20 2025 4:17pm
Disco_Mikey
New vac pump and servo required
Post #648963 Sun Jul 20 2025 5:45pm
jpvd
i kind of guessed that....what i'm asking is has anyone here managed to get a recall paid for by land rover, from such a long time ago?
although i dont see why a new vac pump would ne needed? - would have thought just a new servo and vacum hoses with a new non return valve, etc?
If not i will have to pay for the work obviously, but hopfully not! Laughing
Post #648965 Sun Jul 20 2025 6:59pm
Worth ago contacting an LR dealer.
They have been recalling the 2005 towbars this month, so maybe they have funds or good customer service!
Post #648966 Sun Jul 20 2025 7:07pm
jpvd
i just got that letter last week...so might as well push for both to be sorted at once...never know! - its worth a try - will let you know how i get on...
if they wont do it, then i am probably looking at around £500 for new servo, vac hoses and labour....would do it myself but dont like messing with the braking system if i can help it....done lots in the past, but i already have the coolant expansion tank that i need to fit, so enough to do already Laughing
might look into an oil catch can on the vacuum hose too....
Post #648968 Sun Jul 20 2025 7:24pm
I must be the only one without a letter!
Post #648969 Sun Jul 20 2025 7:33pm
Disco_Mikey
P017 recall was a plaster. The actual fix is a new vac pump, the internal seals fail and oil migrates into the servo. The modified pipework does (apparently) slow it down, but doesn't cure it fully
Post #648995 Mon Jul 21 2025 9:27pm
