![]() | Home > General (L494) > Breakdown |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1903 ![]() ![]() |
That is the auxiliary battery failed, I had exactly the same happen and Land Rover Assist came out and replaced it and a split controller that had failed. It was just charging the main 12 volt battery and not the auxiliary. 2023 P440e SE Dynamic on order -cancelled
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 142 ![]() ![]() |
Ah, thanks.
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 390 ![]() ![]() |
Is your warranty with LR? If so call out LR assistance, if they can't fix it and have to get your car recovered to your dealer they will arrange a hire car for you.
The guy picking it up put a code scanner on it.
Car finally being fixed today. Diagnosed as a power control unit failure resulting in not enough power going to the aux battery. 2021 P400e Autobiography |
Same fault as mine as I mentioned in my July 1st post. 2023 P440e SE Dynamic on order -cancelled
Well my aux battery is (as far as I know), ok. It was just the power control unit not sending it voltage. 2021 P400e Autobiography |
The Land Rover Assist guy replaced my aux battery more as a precaution because he thought wise to do so. A good guy! |
LR are trying it on a bit. Saying one of my brake discs is corroded and needs replacing. The car only had an MOT a couple of months ago and the brakes were fine then. 2021 P400e Autobiography |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 305 ![]() |
Just a note on the AUX battery - replaced mine a few months ago but the Auto stop/start hasnt worked since - does the new aux battery need coding in? |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 219 ![]() ![]() ![]() |
I replaced both the main and auxiliary battery around 4 months ago, told the BMS via IID tool about the main one but the BMS would not let me do the aux????
Finally got it back.
