![]() | Home > General (L494) > Breakdown |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1906 ![]() ![]() |
That is the auxiliary battery failed, I had exactly the same happen and Land Rover Assist came out and replaced it and a split controller that had failed. It was just charging the main 12 volt battery and not the auxiliary. 2023 P440e SE Dynamic on order -cancelled
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 144 ![]() ![]() |
Ah, thanks.
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 390 ![]() ![]() |
Is your warranty with LR? If so call out LR assistance, if they can't fix it and have to get your car recovered to your dealer they will arrange a hire car for you.
The guy picking it up put a code scanner on it.
Car finally being fixed today. Diagnosed as a power control unit failure resulting in not enough power going to the aux battery. 2021 P400e Autobiography |
Same fault as mine as I mentioned in my July 1st post. 2023 P440e SE Dynamic on order -cancelled
Well my aux battery is (as far as I know), ok. It was just the power control unit not sending it voltage. 2021 P400e Autobiography |
The Land Rover Assist guy replaced my aux battery more as a precaution because he thought wise to do so. A good guy! |
LR are trying it on a bit. Saying one of my brake discs is corroded and needs replacing. The car only had an MOT a couple of months ago and the brakes were fine then. 2021 P400e Autobiography |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 308 ![]() |
Just a note on the AUX battery - replaced mine a few months ago but the Auto stop/start hasnt worked since - does the new aux battery need coding in? |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 221 ![]() ![]() ![]() |
I replaced both the main and auxiliary battery around 4 months ago, told the BMS via IID tool about the main one but the BMS would not let me do the aux????
Finally got it back.
P400E owner 03pl Member Since: 29 Jul 2025 Location: bt440qw Posts: 4 ![]() ![]() |
I recently experienced a serious safety issue with my Range Rover and wanted to understand if it was just my car or something wider. After doing some digging, I’ve found multiple posts across forums describing exactly the same braking failure — this seems to be a widespread and very dangerous problem.
If anyone does report it - DM me? |
