Home > General (L494) > Breakdown
SpiderPig
Breakdown
Got in the car this morning and started the engine.
Bongs from the display, Hill descent and Stability control not working, brake pedal also very heavy.
I turned it off and tried again 30 minutes later, but nothing got cleared.
Call my local Land Rover service dept (I have warranty) and they want me to recover the vehicle to themselves so they can look at it. I was told they'd look at it between scheduled repairs and that courtesy vehicles are booked 4-5 weeks away.
So I'm left with sharing my wife's Fiesta until it's sorted out. 2021 P400e Autobiography
Post #648641 Tue Jul 01 2025 11:43am
jimbg
That is the auxiliary battery failed, I had exactly the same happen and Land Rover Assist came out and replaced it and a split controller that had failed. It was just charging the main 12 volt battery and not the auxiliary. 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #648643 Tue Jul 01 2025 12:31pm
SpiderPig
Ah, thanks.
I'll let Land Rover know. At least it's a first place for them to look. 2021 P400e Autobiography
Post #648644 Tue Jul 01 2025 12:40pm
timhum
Is your warranty with LR? If so call out LR assistance, if they can't fix it and have to get your car recovered to your dealer they will arrange a hire car for you.
At least that was my experience on my many call-outs. Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #648645 Tue Jul 01 2025 1:51pm
SpiderPig
The guy picking it up put a code scanner on it.
ABS Control unit failure, and about 30 other associated failures.
Lets see how LR deals with it.
I have LR Warranty, but not the Assistance add on unfortunately. 2021 P400e Autobiography
Post #648647 Tue Jul 01 2025 4:04pm
SpiderPig
Car finally being fixed today. Diagnosed as a power control unit failure resulting in not enough power going to the aux battery. 2021 P400e Autobiography
Post #648873 Wed Jul 16 2025 1:50pm
jimbg
Same fault as mine as I mentioned in my July 1st post. 2026 P460e Autobiography on order
2006 HSE
Post #648874 Wed Jul 16 2025 3:25pm
SpiderPig
Well my aux battery is (as far as I know), ok. It was just the power control unit not sending it voltage. 2021 P400e Autobiography
Post #648875 Wed Jul 16 2025 3:54pm
jimbg
The Land Rover Assist guy replaced my aux battery more as a precaution because he thought wise to do so. A good guy! Thumbs Up 2026 P460e Autobiography on order
2006 HSE
Post #648881 Wed Jul 16 2025 6:27pm
SpiderPig
LR are trying it on a bit. Saying one of my brake discs is corroded and needs replacing. The car only had an MOT a couple of months ago and the brakes were fine then. 2021 P400e Autobiography
Post #648905 Thu Jul 17 2025 11:19am
Karlp606
Just a note on the AUX battery - replaced mine a few months ago but the Auto stop/start hasnt worked since - does the new aux battery need coding in?
Post #648908 Thu Jul 17 2025 11:51am
skid1963
I replaced both the main and auxiliary battery around 4 months ago, told the BMS via IID tool about the main one but the BMS would not let me do the aux????
Stop/start wasn't working before change but is now so i would suggest it doesn't matter about telling the car it has a new aux battery Question 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged - Gone
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #648910 Thu Jul 17 2025 12:45pm
SpiderPig
Finally got it back.
* Investigate brake pedal feeling stiff. Plugged in vehicle to find fault codes. Found codes relating to power distribution box. PSDB powers secondary battery which powers brake booster. Fault with PSDB wasn't powering battery or brake booster, causing fault. Replaced PSDB and battery.
* Replaced steering UJ as identified split on VHC.
* Replaced rear diff pinion seal which was causing leak identified on VHC.
* Investigate EV mode inop on cold star. Found fault codes relating to HV heater. Attempted unlock of HV heater. Unlock unsuccessful. Requires new. Fitted new HV heater and programmed. Tested EV operation, all ok.
I have no idea how much that would cost if I didn't have warranty. 2021 P400e Autobiography
Post #648925 Fri Jul 18 2025 12:21pm
P400E owner 03pl
I recently experienced a serious safety issue with my Range Rover and wanted to understand if it was just my car or something wider. After doing some digging, I’ve found multiple posts across forums describing exactly the same braking failure — this seems to be a widespread and very dangerous problem.
In my case, I was nearly killed in an accident. While trying to stop at traffic lights, I hit the brakes and the pedal pushed back into my foot. For 1–2 seconds, there was almost no braking. I ended up in the junction — almost hit broadside by a truck, with my wife and kids in the car.
An expert looked into the issue and confirmed it's a known design defect. Land Rover knows about it. It relates to the auxiliary battery — when that battery fails or voltage drops, it doesn’t trigger a proper warning, and in that state, it interferes with the system that switches from regenerative to hydraulic brakes. In those moments, the braking effectively fails.
I’ve been advised to report this to the DVSA (UK regulator) using this link: https://www.gov.uk/vehicle-recalls-and-fau...ety-defect — the process took less than 10 minutes.
In my case, the conclusion was clear: the car does not meet safety regulations in its current form. And it’s not the only JLR vehicle affected — the I-Pace had to be recalled globally for a very similar issue.
So if you’ve had even a single episode like this — please report it. It’s likely a matter of time before it happens again. All of these cars will eventually degrade, and the fault could return. Land Rover won’t act unless forced to — but if enough people report the issue, DVSA will force a recall and fix.
Please — it only takes 10 minutes. Report it. It could save someone’s life.
Post #649154 Tue Jul 29 2025 5:19pm
P400E owner 03pl
If anyone does report it - DM me?
Post #649159 Tue Jul 29 2025 6:06pm
