Home > General > Parts for a 2007 Range ROVER Sport
Meshan
Have them blanked for less L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648741 Mon Jul 07 2025 8:31pm
Benji
If they are blanked off will it fail the MOT on emissions or affect the running of it or fuel consumption?
I presume to blank off the EGRS will cost just as much in labour charges? 4 or 5 hours to blank them?
Post #648746 Mon Jul 07 2025 9:06pm
Meshan
Technically it's an MOT failure as its part of the cars emission system. However, it's deep in the engine so you can't see it unless you go looking for it. Blanking them off stops the soot recirculation in the engine so that's a benefit.
Blanking will cost less. Just make sure you get the software patch as well or you will get a warning light L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648748 Mon Jul 07 2025 9:12pm
Benji
Ok thanks I will look into blanking them off if it doesn't affect the engine or performance? I guess i will save about £500 for the cost of buying two EGR valves
Post #648749 Mon Jul 07 2025 9:28pm
Benji
Where do I get the software patch from? Is it the firm supplying the blanking kit?
Post #648753 Tue Jul 08 2025 12:05pm
usually is it not recommended to blank the V8's
A patch would cost at least £200
Patch from here
https://bellautoservices.co.uk/store/rrs-3...-road-use/
I assume you need to pay someone to install it on top of that ?
or purchase a tool yourself to do it. £425. However this tool does hold its value, and would be of use to you while you own the car.
425+180 = £605 + blanks + installation
Post #648754 Tue Jul 08 2025 12:42pm
Meshan
I had mine done by Bodsy and it cost far less than that.
EGR blanks and a software patch. L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648755 Tue Jul 08 2025 12:58pm
Benji
Andy,
Why is it not recommended to blank the EGRs on a V8TD?
From what different people are saying it maybe safer to replace my EGRs with new valves rather than blank them off?
Craddocks seem to be the cheapest at around £500 plus £400 labour. Quite a dear job in the end!
Post #648756 Tue Jul 08 2025 1:10pm
I don't know why. Mikey on here, who knows these engines says not to on the V8.
Cheapest thing is probably just to change the 1 EGR, assuming someone is confident they know which side is faulty
Post #648757 Tue Jul 08 2025 1:16pm
Benji
Ok thanks but it was recommended by my local LANDROVER specialist to change both EGRs, although only one leaking.
I will probably get both valves changed with it being such a big job. I don't like the thought of blanking them off especially if it affects the emissions then the MOT?
Post #648758 Tue Jul 08 2025 1:22pm
