![]() | Home > General > Parts for a 2007 Range ROVER Sport |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
worth a look.
Benji Member Since: 27 Apr 2025 Location: Cheshire Posts: 32 ![]() ![]() |
Thanks I'll take a look at that site today. I've looked at Rimmer Bros and they seem reasonable. Would you recommend OEM parts for the brake discs and pads? |
Nope |
Are these the EGR valves I need? They don't appear to come with gaskets/seals so assume I will have to source elsewhere?
The EGR valves look completely different to the ones on the RR sport 2.7TD. Is that correct? |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Those that you linked are for a 3.6 TDV8 and are coolers not the valve - is says so - so what engine do you have - if a 2.7TDV6 then no they will not fit. 07MY RRS TDV6
I was just looking at the prices online for the EGR valves and gaskets and the prices and shapes of the units differ tremendously comparing the 2.7 and V8 diesel engines.
I've been told my EGR valves and gaskets should be changed. Should the coolers also be changed as a precaution whilst the valves are being done.
3.6 engine
I've no idea what make my current EGRs are as my local garage said one was leaking and recommended changing both.
Any idea how long it would take to replace both EGRs and the drivers door lock? |
4 hours? |
That's what I thought but I've been quoted 8 hours at a labour charge of £420 with no vat. Is that reasonable compared to main dealer labour charges? |
Does anyone know where I can get 2 new EGR VALVES including gaskets for a 2007 Range ROVER HSE V8TD?
