![]() | Home > General (L494) > EGT sensor bank 1 replacement |
Lee350 Member Since: 07 Feb 2022 Location: Norwich Posts: 21 ![]() ![]() |
hi. did you fix this? i have the part but seems much confusion on what side bank 1 is.
Jacko2005 Member Since: 24 Jan 2023 Location: Hull East Yorkshire Posts: 2 ![]() ![]() ![]() |
Did you ever find I have same problem |
yes i did. As you look at the engine its on the right. down need the manifold and had to move the fuel filter to get to it. |
Woppyman Member Since: 08 Jul 2015 Location: England Posts: 66 ![]() ![]() ![]() |
How hard was it to do this job? I have heard horror stories that you need special tools and if it snaps off its an engine out job! Evoque HSE Dynamic
was a pain in the arse. So the tool you buy with the sensor is ok but more for install. In the end i just cut the wire off and put a standard deep socket on it and undone it. Risk but wire was a mess after trying with the proper tool.
Thanks for letting me know. I might hand this one over to the pro's! Evoque HSE Dynamic
teldec Member Since: 29 Dec 2019 Location: essex Posts: 84 ![]() ![]() |
Put mine in to a specialist and it snapped in the exhaust, they got it out but it was not cheap |
Same here. Left it with a local indie, they have snapped it off. they are taking manifold off to get to it. even main dealers say they outsource removal of snapped EGTs. Nightmare Evoque HSE Dynamic
