Home > General (L494) > EGT sensor bank 1 replacement
IRBails
Australia
Looked at search and couldn't find. Have code that says this need replacement and I am looking for part and any info on how easy or hard the job may be?
SDV8 2018 with 169,000 k's, Car is running fine but would like to fix .
Thanks M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #622065 Sun Feb 20 2022 12:59am
Lee350
hi. did you fix this? i have the part but seems much confusion on what side bank 1 is.
Older TDV8 i think is on the right as you look at engine from the from and the SDV8 its on the left as you look at engine from the front.
Could you confirm?
Post #627877 Wed Nov 02 2022 5:11pm
Jacko2005
England 2013 Range Rover Sport TDV8 Autobiography Sumatra Black
Did you ever find I have same problem
Post #630203 Tue Jan 24 2023 11:06pm
Lee350
yes i did. As you look at the engine its on the right. down need the manifold and had to move the fuel filter to get to it.
Post #630210 Wed Jan 25 2023 2:52am
Woppyman
United Kingdom 2012 Range Rover Sport Supercharged Autobiography Siberian Silver
How hard was it to do this job? I have heard horror stories that you need special tools and if it snaps off its an engine out job! Evoque HSE Dynamic
5.0 Charger MY12
Post #647886 Tue May 06 2025 8:49pm
Lee350
was a pain in the arse. So the tool you buy with the sensor is ok but more for install. In the end i just cut the wire off and put a standard deep socket on it and undone it. Risk but wire was a mess after trying with the proper tool.
I used loads of release fluid over the course of the day.
Post #647891 Wed May 07 2025 11:00am
Woppyman
Thanks for letting me know. I might hand this one over to the pro's! Evoque HSE Dynamic
5.0 Charger MY12
Post #647892 Wed May 07 2025 11:10am
teldec
Put mine in to a specialist and it snapped in the exhaust, they got it out but it was not cheap
Post #647909 Thu May 08 2025 10:38pm
