![]() | Home > General (L494) > EGT sensor bank 1 replacement |
Lee350 Member Since: 07 Feb 2022 Location: Norwich Posts: 21 ![]() ![]() |
hi. did you fix this? i have the part but seems much confusion on what side bank 1 is.
Jacko2005 Member Since: 24 Jan 2023 Location: Hull East Yorkshire Posts: 2 ![]() ![]() ![]() |
Did you ever find I have same problem |
yes i did. As you look at the engine its on the right. down need the manifold and had to move the fuel filter to get to it. |
Woppyman Member Since: 08 Jul 2015 Location: England Posts: 68 ![]() ![]() ![]() |
How hard was it to do this job? I have heard horror stories that you need special tools and if it snaps off its an engine out job! Evoque HSE Dynamic
was a pain in the arse. So the tool you buy with the sensor is ok but more for install. In the end i just cut the wire off and put a standard deep socket on it and undone it. Risk but wire was a mess after trying with the proper tool.
Thanks for letting me know. I might hand this one over to the pro's! Evoque HSE Dynamic
teldec Member Since: 29 Dec 2019 Location: essex Posts: 88 ![]() ![]() |
Put mine in to a specialist and it snapped in the exhaust, they got it out but it was not cheap |
Same here. Left it with a local indie, they have snapped it off. they are taking manifold off to get to it. even main dealers say they outsource removal of snapped EGTs. Nightmare Evoque HSE Dynamic
Ok, they got it out. Cost £1,640. Warranty company only paid £181 towards it due to them finding a sensor for £64.00 on LRParts and giving £65.00 per hour at book rate (40 mins work). Reality was it was more like 10 hours work and over £150 for a genuine sensor. Not going to waste my money on warranty's, will put into a savings acct instead Evoque HSE Dynamic
ouch |
I have a theory that making the SDV6/8 Euro 6 compliant was a retrofit design. You would never put a Exhaust Sensor somewhere so inaccessible if you were designing the engine from ground up. Evoque HSE Dynamic
