![]() | Home > Maintenance & Modifications > Gap - iid tool |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117
I’ve only needed to update it for specific ccf edits
| Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 124
Thanks for the input Guy's.
| Jools-RR Member Since: 11 May 2025 Location: Bristol Posts: 6
I have just switched from my second Defender L633 to a 2025 RR Sport L461 and have a GAP iid tool that I have used for many tweaks to the CCF settings on the Defenders to enable many things. On the UK Defender forum there is a sticky long thread with lots of instruction of working CCF adjusts, but cant see the same here.
Thanks for that great info |
| daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 219 |
I'm interested in buying one of these tools, any recommendations ? |
I would suggest the G4 Gap tool.
| Ironhorse Member Since: 21 May 2024 Location: bromsgrove Posts: 31
Hi Jools
Hi Nige, the option is in the Gap tool CCF file list when you go to the menu. I connected to the car, went to the CCF menu option and scrolled down to it. Didn't need to do anything special. |
cheers ill give it a go |
| Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 117
Hi im sure if you insert seat belt 10 times quickly this disables the bong completely |
Yep done the seat belt thing 10 times when I first had it, no bongs
| Shadwell Member Since: 10 Oct 2024 Location: South coast Posts: 16
I will try that Well hear I am |
Took 3 or 4 attempts to get it sorted. worked on my 22 plate transit also,
