Home > Maintenance & Modifications > Gap - iid tool
Kevin-t
Gap - iid tool
Hi All.
I have a Gap - iid tool. Bought approx 3.5 years ago. works as it should.
It reads and clears faults as it should, and that's in a nutshell all I do with it.
However, pondering, should it be updated every now and again?
As we we do with our phones and pc's etc.etc.
I have my phones, pc's, iPads etc.etc set to update themselves. (Latest version).
What about the iid tool????
Anyone.
Kevin-T...... Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #645494 Wed Nov 27 2024 9:07am
I’ve only needed to update it for specific ccf edits
Or if something odd about live data.
Post #645495 Wed Nov 27 2024 10:36am
Kevin-t
Thanks for the input Guy's.
Had an hour to spare today. So updated anyhow.
Simple task really.
Thumbs Up Thumbs Up Thumbs Up Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #645510 Wed Nov 27 2024 9:27pm
Jools-RR
I have just switched from my second Defender L633 to a 2025 RR Sport L461 and have a GAP iid tool that I have used for many tweaks to the CCF settings on the Defenders to enable many things. On the UK Defender forum there is a sticky long thread with lots of instruction of working CCF adjusts, but cant see the same here.
Just posting to maybe help others as 2 adjustments made with the Gap iid tool using the same settings as used on the Defender have worked perfectly.
- Auto stop/start remember last setting
MultiCAN-566 MHLastUserMode =
Enabled
- Stop driver assistance resetting to HIGH
MultiCAN-889 GSR2 EU Market Ft
Change it to Non GSR2 Country
Changing these 2 settings mean that when re starting the car it starts up in same mode as you last had it set, and you can then turn the driver assistance or auto/start on/off as required.
I'm also going to change the seat belt warning to minimal which is quite good as dings 3 times when you start up and then remains quiet, good for when your moving around and in and out the vehicle and stops the constant ''ding ding''
Seat Belt Reminder
MultiCan-717 Front Belt Minder
Belt Minder change to = Minimal
Multican-737 Rear Belt Minder
Rear Belt Minder change to = Minimal
Post #648144 Mon May 26 2025 5:46am
Thanks for that great info
Post #648146 Mon May 26 2025 8:55am
daxmatt
I'm interested in buying one of these tools, any recommendations ?
Post #648153 Mon May 26 2025 7:10pm
Jools-RR
I would suggest the G4 Gap tool.
Buy from a UK supplier to avoid the unknown customes duty. Maybe Bell Auto Services, that is where I got mine from.
Post #648162 Tue May 27 2025 4:50am
daxmatt
Post #648164 Tue May 27 2025 5:14am
Ironhorse
Hi Jools
Did you have to ask Patrick for the full ccf list for the auto stop/start file or is it on there as standard ,
I asked Patrick some time ago if it could be disabled with the iid tool he said no and did not mention anything about that file
Cheers Nige
Post #648167 Tue May 27 2025 8:38am
Jools-RR
Hi Nige, the option is in the Gap tool CCF file list when you go to the menu. I connected to the car, went to the CCF menu option and scrolled down to it. Didn't need to do anything special.
Post #648172 Tue May 27 2025 7:21pm
Ironhorse
cheers ill give it a go Thumbs Up 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #648173 Tue May 27 2025 9:44pm
Toonraider
United Kingdom 2008 Range Rover Sport TDV6 HST Stornoway Grey
Hi im sure if you insert seat belt 10 times quickly this disables the bong completely
Post #648371 Sun Jun 15 2025 10:08am
Ironhorse
Yep done the seat belt thing 10 times when I first had it, no bongs
Sorted Very Happy 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #648374 Sun Jun 15 2025 6:22pm
Shadwell
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Stornoway Grey
I will try that Well hear I am
Post #648402 Tue Jun 17 2025 4:54pm
Ironhorse
Took 3 or 4 attempts to get it sorted. worked on my 22 plate transit also,
That one took about 8 attempts 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #648417 Tue Jun 17 2025 10:13pm
