Home > Technical > P400e idle problem
Benidorm Mick
2008 Range Rover Sport TDV8 HSE Stornoway Grey
P400e idle problem
My P400e has started to run rough on tick over. Usually happens on 40+ mile journey. Example: Pull up at a junction and feels like the idle revs are too low so car splutters and engine shaking. Can also feel it while driving when you take your foot off the gas pedal... although runs fine when you press the gas pedal... Came home from a 90 mile drive today, last 26 miles on motorway with no problems... pulled into my driveway, put the car in park, and there it was, struggling to keep running, engine shaking like it was being starved of fuel. Stopped the engine, started it again and it ran perfectly...
Has anyone had this issue or know wtf is happening??
2018 RRsport P400e 2L petrol.
Thanks Confused
Post #633402 Sun May 28 2023 9:37pm
Lookaneagle
Italy
Did you solve your issue sir, mind sharing the fault and remedy?
Post #647276 Sat Mar 15 2025 11:57am
rk7
@Benidorm - Did you ever get to the bottom of this and find a solution? Be good to know if what I am experiencing is something similar.
Thank you,
RK
Post #647946 Sun May 11 2025 6:32pm
Vvt solonoids. 2 off
https://www.jaguarforum.com/threads/how-to...st-1672009
Post #647952 Sun May 11 2025 8:42pm
rk7
Thank you.
I actually just replaced both of mine with the newer design following the same guide. It was a faff on the p400e, but it’s done now. It made a difference but there is still something there.
I’m thinking it might be the PCV valve as I noticed there’s a bit too much oil in the intake before turbo and only poor PCV can do that. I’ll check that out next.
Post #647953 Sun May 11 2025 9:23pm
If you have a pre 2020 year, Is the timing chain rattling on cold start.
Maybe needs a new chain and tensioner
JR vehicle services do them.
Post #647957 Mon May 12 2025 6:02am
rk7
It has tappet type noise all the time when the car is running to be honest. Almost sounds like an injector issue.
In the back of my head I’m thinking it may just be the chain. No PCM codes now though. It did have the codes for solenoid prior to fixing them.
I’ll try and up load a video here.
Post #647958 Mon May 12 2025 6:21am
rk7
Here’s the video link: https://imgur.com/a/u05yE23
When listening in person it seems like the noise is coming from the front middle of the engine. The tappet noise that is, and not from the rear end.
Post #647959 Mon May 12 2025 6:38am
I'm still learning about the engine.
I know it has a shaft running though it, off the timing belt, which is another problem area, so I wonder if its that. Complete guess.
I guess you should take it to an expert, and maybe get the timing chain done anyway, for peace of mind.
Post #647964 Mon May 12 2025 4:16pm
Burhan
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Alaska White
@rk7 did you ever fix the issue? I have the same issue. Its been back to the dealer multiple times, a master technician looked at it but still nothing. Its still under warranty from JLR and they say its normal. Idling rough when cold and the engine is very jumpy/rough at idles when driving while the engine is cold. No issue when its on operating temperature however. Dealer already replaced solenoids. TIA
Post #648833 Mon Jul 14 2025 9:08pm
rk7
@burhan - sorry for the late reply here. After showing it to an expert it turned out thats how these engines sound. So after replacing the 2 solenoids, my issue was resolved.
Post #649447 Sat Aug 16 2025 5:21pm
