![]() | Home > Technical > P400e idle problem |
Lookaneagle Member Since: 15 Mar 2025 Location: Bolzano Posts: 4 ![]() ![]() |
Did you solve your issue sir, mind sharing the fault and remedy? |
rk7 Member Since: 11 Apr 2025 Location: Didcot Posts: 8 ![]() ![]() |
@Benidorm - Did you ever get to the bottom of this and find a solution? Be good to know if what I am experiencing is something similar.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5123 ![]() ![]() ![]() |
Vvt solonoids. 2 off
Thank you.
If you have a pre 2020 year, Is the timing chain rattling on cold start.
It has tappet type noise all the time when the car is running to be honest. Almost sounds like an injector issue.
Here’s the video link: https://imgur.com/a/u05yE23
I'm still learning about the engine.
Burhan Member Since: 14 Jul 2025 Location: Amsterdam Posts: 1 ![]() ![]() ![]() |
@rk7 did you ever fix the issue? I have the same issue. Its been back to the dealer multiple times, a master technician looked at it but still nothing. Its still under warranty from JLR and they say its normal. Idling rough when cold and the engine is very jumpy/rough at idles when driving while the engine is cold. No issue when its on operating temperature however. Dealer already replaced solenoids. TIA |
@burhan - sorry for the late reply here. After showing it to an expert it turned out thats how these engines sound. So after replacing the 2 solenoids, my issue was resolved. |
