Home > General (L494) > No Start and No Crank
RRS4ED
Hi everyone, hope you all had a happy Christmas and New Year.
My Rangie died on me today and doesn't want to start.
Bit of background information:
Last week my alternator packed in, had a fault code for mechanical performance for the alternator and battery light on, so ordered a replacement.
I fitted it yesterday, car started up fine, no more battery light and fault code cleared. My diagnostic tool showed 14.5v so thought all fixed.
Took it for a test drive this morning round the block and it died, not even half a mile drive.
There is no voltage under the charging points under the bonnet.
I tested the big fuses in the boot area and they all seem to be fine.
I know the ground cables in the wheel arch common on these and i cleaned and put dielectric grease on these in summer as preventative maintenance but haven't checked these yet.
I have got a code in PCM called P0A0F-00 Engine cannot start.
I can hear something click but don't know if its starter or a any relay.
I also know crank is common on these, could check to see if its engine but i think its related to this alternator issue.
The nut holds thick wire behind the alternator was hard to undo as it was tight and i tightened it as hard as i could and thought may be that came off.
I apricate its a long one but if anyone can shed light i would be so grateful.
Post #646262 Sun Jan 12 2025 5:22pm
RRS4ED
I am a bit further on, the main fuse 450A is blown that lives on the right hand side in the boot.
I am not sure why but if i find out i will update here.
Huge shout out to 2RRS who kindly gave me the wiring diagram.
Post #646307 Tue Jan 14 2025 6:56pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Always a pleasure to keep members away from main dealers Bow down
Post #646310 Tue Jan 14 2025 10:12pm
RRS4ED
Issue now resolved, the red rubber cap wasn't seated properly and i think electricity jump causing a short.
Its now all resolved but it would of been hard without the wiring diagram
Post #646404 Tue Jan 21 2025 11:12am
FRL494RM
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Re: No Start and No Crank
Glad to hear you got this sorted!! I seem to be having the same issue, recently bought a non-runner l494 as a bit of a project - it came with no power to the car whatsoever, after a bit of investigation I discovered that the main electrical cables under the front wheel arch weren't attached to anything as the starter motor had been pulled out and the battery was toast, fitted a new battery and starter motor to the car and now the car has power, ignition and everything turns out but car won't crank or turn over, there's just a short few clicks coming from near the rear boot fuse box but I've pulled/checked/tested all of the fuses + relays in the 3 main fuse boxes and tested them with a relay tester and power probe and all seem fine, noticed however that I'm not getting any power/voltage at the battery posts under the bonnet and plugged in my scanner and have the exact same error code as you which is the only error code I'm getting as well, gonna have a look for the main 450 amp fuse you mentioned and hopefully that'll end up being my issue as well, was it hard to get to?
Post #648267 Thu Jun 05 2025 6:44pm
RRS4ED
Before you dive there check if you got voltage in the engine bay!
It was bit of a pain to get too, but doable. Fuse is only £6 of eBay. Search for Land Rover 450a fuse
You have to take the side panel on the right hand side in the boot off,
The anchor points for cargo net
Then think I had to take spare wheel out
And then you can pull the lining in the spare wheel to side
Then you need to take a big plastic cover off
Then you need to take another cover off under neath and you can see the fuse. There is another one next to it rated 350A
Make sure disconnect all the batteries before you do this job!
Annoyingly I didn’t
Post #648268 Thu Jun 05 2025 6:57pm
FRL494RM
Hey there RRS4ED!
Appreciate the quick response! Good shout about checking in the engine bay, forgot to check there, I already ordered one of the 450a fuses off of ebay last night in the hopes that this was my issue and seeing as they were only cheap Laughing
Luckily I already have most of the rear trim pieces removed so will hopefully be able to find it tomorrow, had a quick look today but only during my lunchbreak whilst working from home and uncovered some of the main fuses under a plastic cover beside the aux battery but the highest rated amp one there was 250 along with others in the 30/40s, will have another look tomorrow once I get the batteries disconnected, thanks for your help!
Post #648269 Thu Jun 05 2025 7:17pm
RRS4ED
You need to dig deeper, here are some photos when I done this
Post #648270 Thu Jun 05 2025 8:49pm
FRL494RM
Ah okay cool, thanks for letting me know and for the helpful photos! I did think as much but just ran out of time today unfortunately, luckily the weekend begins tomorrow though so I can have a good old dig at it Smile will let you know how I get on, hopefully the fuse arrives by Saturday or I'll be a bit stuck lol
Post #648271 Thu Jun 05 2025 9:05pm
FRL494RM
Apologies for the delayed update, things have been a bit hectic at work, so I disconnected both batteries and replaced that main 450a fuse - found it pretty easy to get to thanks to those pictures you shared, and it turns out my one was blown as well as when I replaced it I then had voltage under the bonnet at the battery posts however when I tried to start the car it still didn't crank or start etc Big Cry so left it again to sit for a few days...
Noticed yesterday that I now have no power at the battery posts again so seems like the fuse has blown again Rolling Eyes so in trying to figure out what blew the fuse, had a look at the main engine fuse box again and it looked like f20 and the one beside it were missing so I've added some in and will be replacing the main fuse again today and seeing if that helps!
Post #648475 Sun Jun 22 2025 11:34am
