![]() | Home > General (L494) > No Start and No Crank |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 45 ![]() ![]() |
I am a bit further on, the main fuse 450A is blown that lives on the right hand side in the boot.
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 224 ![]() ![]() ![]() |
Always a pleasure to keep members away from main dealers |
Issue now resolved, the red rubber cap wasn't seated properly and i think electricity jump causing a short.
FRL494RM Member Since: 05 Jun 2025 Location: Belfast Posts: 5 ![]() ![]() ![]() |
Glad to hear you got this sorted!! I seem to be having the same issue, recently bought a non-runner l494 as a bit of a project - it came with no power to the car whatsoever, after a bit of investigation I discovered that the main electrical cables under the front wheel arch weren't attached to anything as the starter motor had been pulled out and the battery was toast, fitted a new battery and starter motor to the car and now the car has power, ignition and everything turns out but car won't crank or turn over, there's just a short few clicks coming from near the rear boot fuse box but I've pulled/checked/tested all of the fuses + relays in the 3 main fuse boxes and tested them with a relay tester and power probe and all seem fine, noticed however that I'm not getting any power/voltage at the battery posts under the bonnet and plugged in my scanner and have the exact same error code as you which is the only error code I'm getting as well, gonna have a look for the main 450 amp fuse you mentioned and hopefully that'll end up being my issue as well, was it hard to get to? |
Before you dive there check if you got voltage in the engine bay!
Hey there RRS4ED!
Ah okay cool, thanks for letting me know and for the helpful photos! I did think as much but just ran out of time today unfortunately, luckily the weekend begins tomorrow though so I can have a good old dig at it |
Apologies for the delayed update, things have been a bit hectic at work, so I disconnected both batteries and replaced that main 450a fuse - found it pretty easy to get to thanks to those pictures you shared, and it turns out my one was blown as well as when I replaced it I then had voltage under the bonnet at the battery posts however when I tried to start the car it still didn't crank or start etc |
