| RRSPORT.CO.UK | ||
|  | Home > General > Intermittent None Starting - Hard Brake Pedal On Start Up |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 113      | I had this myself.
|  Tue Jul 16 2024 7:33pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up Rallyesport
|  Mon Jul 22 2024 7:13pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up all - update
|  Thu Aug 01 2024 8:18pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Known issue. PCM+IPC software update, assuming you don't have a leaking servo    | ||
|  Thu Aug 01 2024 9:02pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up Disco-mikey
|  Fri Aug 02 2024 7:27pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | A decent indy who has a genuine version of SDD can do the update   | ||
|  Sat Aug 03 2024 5:31am |
|  Sat Aug 03 2024 6:22am |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 113      | Hello again,
|  Thu Sep 12 2024 8:25pm |
|  Fri Sep 13 2024 7:22pm |
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231      | Hi, I just wondered if you got the update done and if it improved the issue. I only ask as I've noticed the past couple of weeks that mine has been doing exactly the same thing a couple of times. A rock hard brake pedal and then a click when I press start. It did it twice this mornig before successfully engaging the starter.
|  Tue Dec 10 2024 7:00am |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 113      | I still get the hard pedal on the odd occasion myself.
|  Tue Dec 10 2024 9:41am |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up all,
|  Tue Dec 10 2024 8:07pm |
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231      | Thanks for your replies guy's, much appreciated.
|  Wed Dec 11 2024 6:01am |
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 435    | Check your battery connections. The 10mm bolt that held one of the secondary cables onto the main pos clamp needed nipping up. | ||
|  Wed Dec 11 2024 6:48am |
| Posting Rules
