![]() | Home > General > Intermittent None Starting - Hard Brake Pedal On Start Up |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 112
I had this myself.
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167
Eh up Rallyesport
Eh up all - update
Known issue. PCM+IPC software update, assuming you don't have a leaking servo |
Eh up Disco-mikey
A decent indy who has a genuine version of SDD can do the update |
Eh up
Hello again,
Eh up Rallyesport
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231
Hi, I just wondered if you got the update done and if it improved the issue. I only ask as I've noticed the past couple of weeks that mine has been doing exactly the same thing a couple of times. A rock hard brake pedal and then a click when I press start. It did it twice this mornig before successfully engaging the starter.
I still get the hard pedal on the odd occasion myself.
Eh up all,
Thanks for your replies guy's, much appreciated.
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 435
Check your battery connections. The 10mm bolt that held one of the secondary cables onto the main pos clamp needed nipping up. |
| All times are GMT |
