Home > Technical > Restricted performance, red triangle and no codes…
Max100
Northern Ireland
Hi, last night while joining a motorway from on slip the car went into limp mode with red triangle showing. I had my gap tool with me and plugged it in at the next exit. It did not show any codes. I pressed ‘clear all ‘ anyway and the red triangle went out when I moved off again. The car drove fine all the way back. Any ideas ? Oh it’s. 2012 3.0sdv6 sport. Thanks
Post #637125 Tue Nov 07 2023 2:59pm
Max100
Northern Ireland
Turns out it’s a split inlet manifold.
Post #637323 Wed Nov 15 2023 10:47pm
Stevepd
A good find and a cheap fix. It's one of those things I'm afraid. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #637332 Thu Nov 16 2023 6:55am
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Good morning,
I am now experiencing this issue. Can you advise how you found out it was a split inlet manifold please?
The vehicle just spent a few days at a local indie and they were unable to find any physical issue at all and again no codes showing up on either my GAP iiD tool nor their scanner
Thank you "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #640958 Fri Apr 05 2024 11:35am
The way my indie described it when I took mine in for the same issue, they basically put it in gear, stand on the brake pedal and apply revs. One then hears a whistling noise from the split manifold. 2012 SDV6 - it's missing a couple of cylinders
Post #640959 Fri Apr 05 2024 11:49am
Max100
Northern Ireland
Hi, we did a smoke test and there sure enough wisps of smoke from the rear left corner.
Post #640969 Fri Apr 05 2024 2:40pm
