![]() | Home > Technical > Restricted performance, red triangle and no codes… |
Max100 Member Since: 28 Apr 2019 Location: Belfast Posts: 12 ![]() ![]() |
Turns out it’s a split inlet manifold. |
A good find and a cheap fix. It's one of those things I'm afraid. 2006 2.7 TDV6 HSE in Cairns Blue. |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 99 ![]() ![]() ![]() |
Good morning,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
The way my indie described it when I took mine in for the same issue, they basically put it in gear, stand on the brake pedal and apply revs. One then hears a whistling noise from the split manifold. 2012 SDV6 - it's missing a couple of cylinders
Hi, we did a smoke test and there sure enough wisps of smoke from the rear left corner. |
